Gas tank
Old Nov 8, 2011 | 03:27 PM
scatgo's Avatar
scatgo
Gas tank
Anybody know the rear fuel tank capacity on a 1994 F350 dually? I fill up from a pump with no meter so I don't know and I am trying to figure out my mileage.
Old Nov 8, 2011 | 11:38 PM
oldbird1965's Avatar
oldbird1965
About 19 gallons.
Old Nov 9, 2011 | 01:02 AM
madpogue's Avatar
madpogue
Pickup? 19 gallons. But unless you run it bone dry every time (BAD idea, obviously), it still won't help you estimate the mileage. Option - dispense from the pump into a five-gallon jerry can, then into the truck, and count the number of fills of the can.
Old Nov 9, 2011 | 04:48 AM
scatgo's Avatar
scatgo
I did run it dry this time. I will fill up some 5 Gal. cans to see how much I can get in there. Got 308 from toped off to dry this time. If my math is right thats 15 + MPG @ 20 Gal a tank. Now I know when I get to about 280 It might be a good time to switch to the ront tank. Is the front tank the same size as the back?
Old Nov 9, 2011 | 05:12 AM
Copedawg's Avatar
Copedawg
Little OT: Don't you have a duece and a half? Whats up with that?
Old Nov 9, 2011 | 08:05 AM
madpogue's Avatar
madpogue
Front tank size varies by cab/bed size, but they're all 16-18 gallons.
Old Nov 9, 2011 | 08:35 AM
redman84's Avatar
redman84
My owners manual shows all lwb trucks to have 19 gallon front tanks and 18.2 gallon rears. The exceptions to that being chassis cab trucks having two 19 gallon tanks. It shows swb trucks to have 16.5 fronts and 18.2 rears.
Old Nov 9, 2011 | 08:39 AM
redman84's Avatar
redman84
Which also perplexes the hell out of me since I consistently go 25-40 miles further on my rear tank than front. Maybe the vent mod allows it to actually fill up and the not-modded front can't reach capacity?...
Old Nov 9, 2011 | 09:31 AM
oldbird1965
A real slight OT while we are on the subject of fuel tanks. Is there a rubber gasket or somthing on these tanks at the top? When I fill mine all the way up they leak. If I'm on the road I fill both of them all the way up and when I'm driving I'll run 50 miles on one tank and switch to the other to drain them down a little. If I let it sit with both tanks full they both leak.
Old Nov 9, 2011 | 09:52 AM
madpogue's Avatar
madpogue
Where is it leaking? Top of the tank? Sending unit lock ring? Filler inlet to the tank? Out the filler neck on the bed?
Old Nov 9, 2011 | 10:16 AM
oldbird1965
Good question, I need to drop the tanks and find out. Yes, its from the top someplace.
Daylene Alford
Apr 4, 2017 11:00 AM
mtntop1
Oct 6, 2009 10:04 AM
Fordfreak1978
General Automotive Discussion
13
May 8, 2009 05:33 PM
tscryba
1997 - 2003 F150
Sep 8, 2004 05:08 PM
moose94
Apr 10, 2004 10:43 PM
