1941 Ford 1/4 ton
Old Apr 8, 2003 | 06:48 PM
Ray Martin's Avatar
Ray Martin
Angry 1941 Ford 1/4 ton
I need to know if anyone can tell me how to remove the locking pin from the steering colum without pulling the steering wheel and steering shaft.
Someone tried to steal the truck this winter when I had it stored and they jammed up the key lock so I cannot get a key in to turn the lock.
Thanks, Ray
Old Apr 10, 2003 | 09:28 AM
big1's Avatar
big1
1941 Ford 1/4 ton
This diffenatly isn't a 41 steering column is it?
Old Apr 14, 2003 | 05:41 PM
LBell101's Avatar
LBell101
1941 Ford 1/4 ton
Well, if it's the same as a 38/39...
There should be a set screw holding the lock cylinder in. It's right behind the key entry on the backside. Once that is removed you can pull the lock cylinder out. Then you can slide the locking pin up and down with a screwdriver.
Larry
www.larryscars.com
Old Apr 14, 2003 | 09:53 PM
Bill_Gilder's Avatar
Bill_Gilder
1941 Ford 1/4 ton
If the lock is like the 42-47 lock, there is a pressed in pin in the bottom center of the lock cylinder. I had the same problem in 2 trucks. Drill out the pin about 1/4"deep with a 1/4 drill and the lock cylinder should be able to be pulled out with a sheet metal screw driven into the key hole.
Bill
snakedoc
Aug 25, 2011 02:56 PM
bigtexan99
Apr 13, 2011 05:18 PM
JDPoore
Dec 26, 2004 07:14 PM
Hokie4tec
2004 - 2008 F150
Jun 19, 2004 08:32 AM
