1978 - 1996 Big Bronco
96 Bronco Vacuum line question
Old Sep 28, 2011 | 09:15 AM
psi3000's Avatar
psi3000
I have 96 Bronco with a 5.0 302 in it. I have a vacuum line coming out of the throttle body (not the EGR) on the left side when you are looking head on at the engine bay. I have no idea where this goes as the line has rotten away. Also there is a rectangular canister that mounts to the side of the battery tray that I need to see were the lines go. I have looked at the diagram sticker on the hood but only see the EGR vacuum on the throttle body. Does anyone have any pictures that could help me out please. this thing has been off the road for 4 years and was my beater/offroader. I would really like to get it back into shape.
thanks.
Old Sep 28, 2011 | 02:39 PM
philofab's Avatar
philofab
Do you have a picture of it? The throttle body has a large line meant for coolant to resist icing in cold weather. Many people bypass it when changing coolant lines, it's very common.
Old Sep 28, 2011 | 03:42 PM
psi3000's Avatar
psi3000
No , i dont currently have a pic. I think I have found part of the answer thanks to my local Ford parts department. It looks like it is part of the Fuel vapor canister. The throttle nipple i am referring to goes to the back Vapor Canister Purge Valve and the other line on the Vapor Canister Purge Valve goes to the vapor canister. But where does the other line on the canister go? After I find this out, Im all set.
Old Sep 28, 2011 | 05:18 PM
b4hntn's Avatar
b4hntn
Fuel tank. The canister absorbs vapors from the fuel tank. The purge valve lets them in the engine when the PCM (computer) determines it is the appropriate time.
Old Sep 28, 2011 | 07:50 PM
philofab's Avatar
philofab
Yea, the canister attaches to the roll over valve on each tank.
nintey4f150
Sep 15, 2012 10:44 AM
crawdad
Feb 7, 2006 06:18 PM
THOMASNMARTA
Oct 5, 2003 11:06 PM
69slow
May 11, 2002 06:24 PM
theleetbeagle
Mar 20, 2002 06:34 PM
