What sensor??
Old Sep 14, 2012 | 07:14 PM
nintey4f150's Avatar
nintey4f150
What sensor??
Can someone tell me what the name of the sensor or whatever it is that on a stock 5.0 truck is... Its right by the throttle body and has a vacuum port with a line that goes into the throttle body.. What is it and what's it do?
Old Sep 15, 2012 | 07:30 AM
subford's Avatar
subford
It is called the Canister Purge (CANP) solenoid.
Fuel Tank Venting
Fuel vapors trapped in the sealed fuel tank are vented through the orificed vapor valve assembly in the top of the tank. The vapors leave the valve assembly through a single vapor line and continue to the carbon canister (located in the engine compartment or along the frame rail) for storage until they are purged to the engine for burning.
Canister Purging
Purging the carbon canister removes the fuel vapor stored in the carbon canister. With an EEC controlled EVAP system, the flow of vapors from the canister to the engine is controlled by a Canister Purge (CANP) solenoid, Dual Canister Purge (CANP) solenoids or Vapor Management Valve (VMV) . Purging occurs when the engine is at operating temperature and off idle.
Old Sep 15, 2012 | 07:45 AM
nintey4f150
What are te effects if it isn't hooked up? Mine is plugged in but no vacuum line on it.. I have an aftermarket throttle body so Idk where to run the line
Old Sep 15, 2012 | 07:52 AM
subford's Avatar
subford
You could run the vacuum line from the vacuum ports on top of the upper intake manifold.
If you park it inside maybe gas fumes inside the building.
Pressure buildup in the fuel tanks?
Old Sep 15, 2012 | 07:55 AM
nintey4f150
The one on my truck has one vacuum port of it not a t like pictured.. I also have an aftermarket intake and the vacuum ports that aren't being used and are capped are to big
Old Sep 15, 2012 | 08:12 AM
subford's Avatar
subford
Are you talking about the EGR valve?
Old Sep 15, 2012 | 08:54 AM
nintey4f150
No not the egr
Old Sep 15, 2012 | 08:56 AM
nintey4f150
But that sensor that in front of the egr is what I'm talking bout.. When my truck was stock it had a hose from the vacuum port that ran into the throttle body right in between it
Old Sep 15, 2012 | 09:20 AM
subford's Avatar
subford
I have no idea what you are talking about:
You stock vacuum system is below:
Old Sep 15, 2012 | 10:16 AM
nintey4f150
Pic didn't load... Ok on the stock twin throttle body the is a vacuum port in between the two throttle blades.. The hose coming off it runs to the thing I'm taking about
Old Sep 15, 2012 | 10:27 AM
danr1's Avatar
danr1
Canister purge?
Old Sep 15, 2012 | 10:44 AM
subford's Avatar
subford
X2 ^^^^
The vacuum diagram above was changed for the 5.0L
I linked to a 5.8L before because that is what you have in your profile.
05victorylly
25
Nov 19, 2025 04:53 PM
psi3000
1978 - 1996 Big Bronco
Sep 28, 2011 07:50 PM
strokin'_tatsch
Jul 19, 2010 06:11 PM
jrw2scw
Feb 22, 2009 05:55 PM
dufrain
Sep 5, 2003 07:43 PM
