Looking for a rear lower shock mount
Old Aug 27, 2011 | 08:04 AM
mkrog's Avatar
mkrog
I am in need of a lower shock mount,rear right side. for a 57 F100.does any body sell them? I have checked all my catalogs and can't find any body that has them.If any body know were I can get one please let me know.None of the bone yards around here has any thing that old
Thanks
Old Aug 27, 2011 | 08:06 AM
WALFORD'S 56's Avatar
WALFORD'S 56
pm sent....Bill
Old Aug 27, 2011 | 03:24 PM
bigwin56f100's Avatar
bigwin56f100
Krog,
If your 57 has the 9" rear end you must use a shock mount from a 57-60, unless you just need the shock mount stud.
The lower spring perches/shock brackets are different from the 53-56's compared to the 57-60's
The dana 44's tube was smaller in diameter than the 9" tube and the brackets are specific for each rear end.
I know clear as mud!
Old Aug 27, 2011 | 08:46 PM
spurredon's Avatar
spurredon
Originally Posted by bigwin56f100
Krog,
Is there a left and right with these things. I can't remember without going out and crawling under. I think I have one kicking around somewhere.
Old Aug 28, 2011 | 12:58 AM
mkrog's Avatar
mkrog
Yes there is.
Old Aug 28, 2011 | 04:59 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
B6C-18193-A .. Lower Shock Absorber Mounting Stud-to Spring Seat Cap / Stud: Right/Left is the same / Obsolete
Applications: 1956/58 F100/250 / 1959/60 F100/250 2WD & 4WD // 1956/77 P350 (P Series Parcel Delivery).
MILLER OBSOLETE PARTS in Binghamton NY has 1 = 607-722-5371.
GRIESEL MOTOR CO. in Okarche OK has 5 = 405-263-7242.
All 1957/58 F100's have 9" rear axles, as do 1959/60 F100's without Limited Slip.
1959/60 F100: If Limited Slip was ordered, Ford installed Dana 44 rear axles.
Ditto 1961/67 F100's and some 1968 F100's. 9" with Limited Slip was not offered for F100's until mid-year 1968.
9" rear axle introduced in 1957, Limited Slip in 1959 (for F100/250's & FoMoCo Passenger Cars w/a 9").
Old Aug 28, 2011 | 08:58 AM
mkrog's Avatar
mkrog
Is that the mounting bracket or just the stud ?
Old Aug 28, 2011 | 09:14 AM
NumberDummy
Ford Truck Parts Catalog part number and description: B6C-18193-A Lower Shock Absorber Mounting STUD -to Spring Seat Cap / Right/Left is the same.
You asked for a lower right shock mount, but didn't specify which parts you needed. Since the stud could be stripped or had crystalized and snapped, that's all I listed.
Old Aug 29, 2011 | 08:18 AM
mkrog's Avatar
mkrog
Sorry but thats what the Ford Service Manual calls it.
Old Aug 29, 2011 | 09:54 PM
gearhead1952's Avatar
gearhead1952
I have this set for sale pm if interested. I won't break up the set and sell just the one part tho.
Old Aug 29, 2011 | 10:22 PM
Dano78's Avatar
Dano78
If mkrog is not interested, I'd like to have a shot at them. I'm in need of a set. PM sent, Thanks.
Old Aug 29, 2011 | 11:13 PM
mkrog's Avatar
mkrog
Thank you but that not the right ones,looks like off a 56 or earlier
Old Aug 29, 2011 | 11:26 PM
gearhead1952
I personally pulled these off a 1960 F100.
Old Aug 30, 2011 | 01:05 AM
Dano78's Avatar
Dano78
These should look and mount just like the '53-'56 ones just with the wider 3" spacing for the 9" rear. Correct me if I'm wrong??
Old Aug 30, 2011 | 03:44 AM
NumberDummy
1957/58 F100:
According to the '57/63 Ford truck parts catalog pic, the rear shock has an upper threaded end that fits to the frame bracket, an eye on the other end.
The stud (B6C-18193-A) passes thru the eye, connects to a L shaped bracket (B7C-18132-A ~ R/S = 1957/58 only) that has two mounting holes.
This bracket then mounts below the lower spring cap. The rearmost spring clip (U-bolt) passes thru the lower spring cap, then thru the two holes in the bracket.
The stud is the same as '56, but on '56's, the stud attaches directly to the lower spring cap. 1957/58 is different, uses the bracket which is R/L specific.
B6C-18193-A .. Lower Shock Absorber Mounting Stud / 1957/58-to bracket (to spring cap on '56's) / Obsolete
B7C-18132-A .. Right Lower Shock Absorber Mounting Bracket / Obsolete
BOWMAN SALES & SERVICE in Bowman ND has 1 = 701-523-3257.
No other Ford Dealer, no obsolete parts vendor has any.
