Optima battery?
Old Aug 14, 2011 | 11:05 AM
Coondawg's Avatar
Coondawg
Optima battery?
Does anyone have any experience with Optima or other dry cell batteries?
Truck is 2005 F150 4.6L STX.
Old Aug 14, 2011 | 01:38 PM
danorules's Avatar
danorules
in my experience the optima batteries are very overrated. i tried one with poor results, warned 2 friends not to get them, and they too had problems. i stick with interstate bats and have no problems. long lasting and very reliable. i have had them in many differant cars with the same positive results.
Old Aug 14, 2011 | 04:53 PM
Dave G.'s Avatar
Dave G.
My son has been using the Optima for a few years now. But, initially, had 2-3 go bad in the first couple of years. Current one is probably 4 years old at least.
Dave
Old Aug 14, 2011 | 06:19 PM
ford390gashog's Avatar
ford390gashog
I won't risk being stuck in the middle of no where using an overrated POS battery. That is just me I have had way to many fail on me and would never ever use them again. I myself only use Johnson Controls batteries. I normally get mine at walmart or through my supplier. Very little failure rate and easy warranty if you need it!!
Old Aug 15, 2011 | 08:05 AM
Coondawg's Avatar
Coondawg
Thanks a bunch fellas!
Old Aug 15, 2011 | 08:07 AM
jimmyv13's Avatar
jimmyv13
I had an Optima red top in 3 different vehicles over 7 years and never had a problem.
Old Aug 15, 2011 | 01:44 PM
RISUPERCREWMAN's Avatar
RISUPERCREWMAN
My Optima Red top has been going strong since 2007!
Old Aug 17, 2011 | 02:25 AM
fordtruckman's Avatar
fordtruckman
Did a bit of research a while back and decided on a Die Hard Platinum P-2 ($190) I believe the CCA 930 I can't remember what the old battery was but I know it was quite a bit less. She turns quicker when I turn the key but the real test will be how it reacts with the plow this winter. So far so good though although I have only had it a few months.
Old Aug 17, 2011 | 07:57 PM
TwinSkrewd's Avatar
TwinSkrewd
I'm running a Yellow top with no issues. I needed the yellow to help run the intercooler pump, efans, twin 255lph fuel pumps, and twin fpdm's. Plus a lil 250watt amp. From what I understand the company did go through a rough patch a few years ago and spit out some crappy batteries.
bismic
Oct 27, 2022 07:08 PM
78Southwind
Nov 16, 2016 06:41 PM
zer01
Feb 25, 2015 04:54 AM
diego-ted
Mar 21, 2014 03:16 PM
dredmond
Dec 31, 2012 11:34 AM
