Sponsored by: Real Truck
front drive shaft spinning while in 2wheel drive
Old Jul 14, 2011 | 09:39 AM
stlrisk's Avatar
stlrisk
I have a 1999 Ford F250 super duty 4wheel drive, lifted(really a leveling kit but had to lift rear to compensate), 5.4l. Im having a problem with my front shaft turning while in 2 wheel drive. Hubs aren't locked and its in 2 wheel not 4. I've taken hubs off and the bearing spins free soo I know its in auto. Why is the drive shaft still turning???????
Old Jul 14, 2011 | 11:44 AM
thomabb's Avatar
thomabb
With the truck in 2wd and the hubs in auto;
1) Try to turn the U-joint behind each front wheel. If one will not turn, you have either a bad U-joint or a hub that is not disengaging.
2) Try to spin the front driveshaft by hand. If it feels locked, there is something hokey in your transfer case.
Having said all that, it is not unusual for the front driveshaft to move when in 2wd. It will drift.
Old Jul 14, 2011 | 11:55 AM
stlrisk's Avatar
stlrisk
I forgot to add, yesterday i was toying w it and it did not turn while pulling out of driveway up street and back down to my driveway. But this morning it moved after I reached 40+mph. I noticed it had moved when I arrived at the gas station.
Old Jul 14, 2011 | 12:20 PM
bpounds's Avatar
bpounds
If you are saying your front shaft has turned a little bit, then that is normal. There is enough friction in the hub bearings to make it turn slightly. If you have confirmed that your hubs are free spinning, then you have nothing to worry about.
Old Jul 3, 2013 | 07:12 PM
shirkey42's Avatar
shirkey42
I have a 2000 f250 super duty. Apparently four wheel drive is engaged but hubs and selector switch show its in two wheel drive . Caused front drive shaft to break at rear u joints on front shaft st transfer case. Drive shaft is removed but front axle is still engaged in four wheel drive. Anyone have any suggestions on what to do?
Old Jul 3, 2013 | 10:05 PM
bpounds's Avatar
bpounds
If your driveshaft broke, that means the transfer case is locked in 4WD. You might also have locking hub problems, but hubs being locked in won't break a driveline. Since it appears that both hubs and TC are locked, maybe you should start with checking the electrical system.
drewduncan15
19
Apr 10, 2019 08:37 PM
1993 ford
May 26, 2017 01:52 AM
thejermsr
13
Feb 18, 2017 11:02 AM
tjgalinski
Aug 28, 2015 08:42 AM
golfpro1592
Nov 17, 2010 08:33 PM
