Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: 4WD Guides
- Drive Shaft Reviews
Reviews and comparisons of top products
front drive shaft spinning while in 2wheel drive
I have a 1999 Ford F250 super duty 4wheel drive, lifted(really a leveling kit but had to lift rear to compensate), 5.4l. Im having a problem with my front shaft turning while in 2 wheel drive. Hubs aren't locked and its in 2 wheel not 4. I've taken hubs off and the bearing spins free soo I know its in auto. Why is the drive shaft still turning???????
With the truck in 2wd and the hubs in auto;
1) Try to turn the U-joint behind each front wheel. If one will not turn, you have either a bad U-joint or a hub that is not disengaging.
2) Try to spin the front driveshaft by hand. If it feels locked, there is something hokey in your transfer case.
Having said all that, it is not unusual for the front driveshaft to move when in 2wd. It will drift.
I have a 2000 f250 super duty. Apparently four wheel drive is engaged but hubs and selector switch show its in two wheel drive . Caused front drive shaft to break at rear u joints on front shaft st transfer case. Drive shaft is removed but front axle is still engaged in four wheel drive. Anyone have any suggestions on what to do?
drewduncan15
19
04-10-2019 08:37 PM
tjgalinski
08-28-2015 08:42 AM
golfpro1592
11-17-2010 08:33 PM
