Sponsored by: Real Truck
Heated seats not working?? Here's why mine don't work (Pics & re-assembly details)
Old Jul 2, 2011 | 03:24 PM
martin123456789's Avatar
martin123456789
After like 2 hours of tearing down...
Here why the resistance of my heating element is infinity
I'll take pictures of the painful reassembly and post them.
Old Jul 2, 2011 | 03:26 PM
martin123456789
Part number: ASH Ford P131/U137
603290
04 fs ch th
Can I buy just the element or do I have to buy the whole seat cushion???
Old Jul 2, 2011 | 08:00 PM
martin123456789
Here's how to re-assemble that
Solder your heater element, then verify the resistance
I got this:
Glue the element back on
Like so:
This was the tricky part... when disassembling, I just cut all of them to make it easier, now to put this back together, I'll just use tie wraps (and I'll cut them too if I ever need to undo this again)
Place all the tie wraps, make sure you get the squares on the outer sides so you're not tightening them reverse to what makes sense
This is what I mean, the square end is on the outside.
Just tighten them up, cut the end, rotate them so that the squares on below.
Insert the back support and back heater wires in there, they will be in the back of the joint. Push in, move it left, it should pop in
Screw this first
Put back all the edges (black plastic retention clips, it's easier if you do bottom, left, top then right (i think))
Pass the seatbelt wire through, bolt the seat belt back on the side
Rebolt the hinge
Plug the wires back in & secure them
To put the plastic back, just get the lever through then it's easy
Make sure you put that clip in the back behind the metal piece
Two screws
That one
Two more under the seat that go on the side plastic, clip in the back.
Plug all the wires & make sure the seat can freely move.
You're done!
Old Jul 2, 2011 | 11:31 PM
1975StroppeBaja's Avatar
1975StroppeBaja
Great write up and pics!! This will definitely help someone down the line. Reps for you!
Old Jan 28, 2012 | 05:11 PM
swing4thefence's Avatar
swing4thefence
Can anybody tell me where to find that broken piece from Martin's first picture? I just can't tell from the photo. It's too close up.
Old Jan 28, 2012 | 05:47 PM
AllaboutMPG's Avatar
AllaboutMPG
Don't even have heated seats but I love the write up. Always helps to have cartoons. Reps at ya for takin the time to share.
Old Jun 9, 2012 | 08:12 AM
martin123456789
That little square thing is in the middle of the seat at the back where the upper and lower part meet. You can kind of feel it through the material.
Old Mar 16, 2018 | 05:51 PM
Lubbockguy1979's Avatar
Lubbockguy1979
I know i know old thread. But how did the zip ties hold up on the seat? Need to replace my cover and saw this. Will proba ly get to the seat next weekend
Old Aug 28, 2019 | 10:36 AM
Big Grinns's Avatar
Big Grinns
I got this:
Like so:
Screw this first
Rebolt the hinge
Two screws
That one
You're done!
Passenger side heater works but not mine. I was afraid to tackle it but you've provided exceptional help, pictures, tips!
THIS is why I joined this group! To get help and share ideas about something we have in common.
Thank you!
Old Nov 12, 2019 | 06:03 PM
RoberDen's Avatar
RoberDen
Unhappy Not Exactly Done Today but ...
Ooops, posted in wrong thread!
Old Dec 10, 2019 | 10:25 AM
unleashd's Avatar
unleashd
About halfway through a audio upgrade to the EX....Will post more details when it is complete.
And then, the oil cooler leaks a day after a fresh oil change.... I should have tackled this over the weekend when the weather was better.
Old Mar 15, 2020 | 09:38 PM
TXtinct's Avatar
TXtinct
You'll shoot your eye out
Having issues with my brake lights... I bought a new phone mount/charger, not sure if that is what caused the issue but that's when I noticed. I have no brake lights, my cigar lighter stopped working as well. That is where I had the charger plugged in. Checked all fuses, none blown. Any ideas?
Old Jun 15, 2020 | 06:43 PM
ShelbyHauler's Avatar
ShelbyHauler
Wrong thread
Old Jun 15, 2020 | 08:04 PM
PolarizedPoutine's Avatar
PolarizedPoutine
Also wrong thread...
Last edited by PolarizedPoutine; Jun 15, 2020 at 08:05 PM. Reason: Also wrong thread
Old May 26, 2021 | 10:49 PM
jetkit's Avatar
jetkit
Designed an double dim adapter for a new touch screen radio. Printing it tonight and will fit tomorrow.
