Keyless entry code stopped working
Old Jun 29, 2011 | 08:16 AM
edub152's Avatar
edub152
Just went on a road trip for 13 hours and ran the a/c the whole trip, now upon arriving at our vacation destination, I discovered that my keyless entry door code no longer works. The only thing I can remember is during the road trip, the a/c unit under the passenger kickboard dripped a little(I thought condensation). Could the exessive a/c usage cause my key pad to stop working? Thank you in advance for your help. Man, my '05 Expy has given me a fair share of problems ;(
Old Jul 9, 2011 | 05:34 PM
fstanush's Avatar
fstanush
Did you figure out your issue?
I am having the same problem....keyless entry on door does not respond nor can I program my keyless remote Fobs turning the ignition from 3 to 4 position eight times...seems like a fuse, but nothing blown that I can find nor do fuse listings appear to be related.
By the way, keyless entry on door is wired version, not wireless that needs a battery.
Old Jul 9, 2011 | 11:00 PM
alloro's Avatar
alloro
Try pushing the buttons real, real hard and see if it works. Sometimes the contacts become corroded under the buttons, making contact difficult.
Old Jul 11, 2011 | 06:44 PM
fstanush's Avatar
fstanush
Tried that again...neither Keyless remote (key FOB) nor keyless door entry (door keypad) responds, so can't be programmed. Figured are related and uncommon as haven't seen the two frequently at issue at the same time....
I have checked the fuses in general in the cab and underhood, but is there a specific location/designation?
Old Jul 11, 2011 | 11:39 PM
edub152's Avatar
edub152
I tried the the same fuse checks, but all check ok. Haven't tried programming a fob. All my fobs work. The entry code backlights so it's getting power. I even tried the factory code, but that still didn't work.
Old Sep 13, 2015 | 08:50 PM
osheam's Avatar
osheam
Fix?
Did u ever resolve this and if so how?
crozz
Iowa Chapter
Mar 7, 2017 12:23 PM
crozz
2004 - 2008 F150
Sep 26, 2016 08:16 AM
2002exPSD
Feb 13, 2016 10:35 AM
PROSTOCK
2011 - 2019 Explorer
Jan 19, 2016 09:32 AM
twigsV10
13
Sep 28, 2015 10:33 AM
