On my 1993 F-250 w/ 7.3L. About a month ago my brake lights wouldn't come on unless I pressed really hard on the brakes but now they wont come on at all no matter what I do. Turn signals still work and parking lights still work. I have no idea what this problem can be and I need all advice from simple to complex please.
have you checked the basics like wiring for fulty connections, fuses, relays, could be a bad relay and/or wire or possibly the switch (i think?) if any for the break/light connection may be bad, thats what i would look at first is relays and wiring then fuses
Well I havnt checked anything. I just replaced the whole fuel system after breaking down in Georgia And i just got home and thats when I noticed my brake lights didnt work at all. I'll check them tomorrow when I have some daylight. Thank you very much. All this repair work shot my brain and I cant think clearly anymore
yep, just checked my haynes book (yes and there should also be a switch which i was refering to in my first post) connected to the break pedal that you should check first along with any relays/wires, if that switch is bad you could see these type of issues (its 00:47 in the morning so im tired guys)
Well i took a look at the switch and from just eye balling it. it seems to be ok. but i played around and the brake light comes on after a few pumps on the brake pedal but only for five seconds and it turns off
can you take a pic of the wires in question, im not 100% sure as i have a '95 not a '97 but generaly the wires you want to test are red and black red=hot and black=ground, there may be other wires that may be involved, so others should hopefully chime in that may have more knowledge
The switch can be as pretty as it was the day it was made, what you are not seeing is the brunt contacts inside...
Does your cruise control shut off when you tap the brake??? If it doesnt, check the brake light fuse. If the fuse is OK the brake light switch is most likely shot.
