Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
73 330 ci industrial
Old Jun 8, 2011 | 11:58 AM
whitaker5426's Avatar
whitaker5426
I have a 73 LN 600 with a 330 industrial motor. I have been trying to find motor specs (oil capacity), but had no luck. can anyone help me.
thx
Old Jun 8, 2011 | 02:46 PM
dmanlyr's Avatar
dmanlyr
My 1970 330 holds 8 quarts.
David
Old Jun 10, 2011 | 08:35 AM
whitaker5426
I think there is two differant types of 330 motors, is your an industrial motor?
Craig
Old Jun 10, 2011 | 04:11 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1964/78 FT engines: 330 2V Medium Duty / 330 2V Heavy Duty / 361 2V / 361 4V (1976/78) / 391 4V.
The 330 M/D shares some parts with 352/360 FE engines. The 330 H/D is based off the 361.
With one exception, these engines were only installed in 500 series and larger trucks.
1973/78 F350's made exclusively for U-Haul came with the 300 M/D also known as the 330 X/D (eXrta Duty).
While there were industrial versions of FT engines, a 1973 LN (or any other year/series truck) would not have come with an FT industrial engine.
OP: Post the 4th digit of your LN's VIN. (4th digit-engine code).
Old Jun 11, 2011 | 01:38 AM
Louisville Joe's Avatar
Louisville Joe
I remember those U-Haul F-350's with the 330's in them. Strange how they continued to build them after the F-350's went to 351M's and 400's.
Old Jun 11, 2011 | 04:38 AM
ford390gashog's Avatar
ford390gashog
While FE production ended in 76 FT production continued til 1979. The FT oil pan Will hold a lot of oil!!! You can get 12 in there and still be over 2 inches from the crank. I run those pans on FE engines because I like them over the stock or aftermarket FE pans.
Old Jun 13, 2011 | 12:54 PM
whitaker5426
how would i determine if i have an fe or an ft motor. it is in a 1973 ln 600.
Old Jun 13, 2011 | 01:05 PM
85e150's Avatar
85e150
If it is an original engine, it is an FT.
The FT uses a front engine mount as pictured here:
Image:FTmount.jpg - BumpWiki
The crank snout is a larger diameter, and the exhaust manifolds are different. There are several internal differences as well.
Ford FT vs. FE - BumpWiki
Old Jun 14, 2011 | 04:27 PM
whitaker5426
It is a FT, so what would be the capacity of that oil pan . It looks to be a deep sump pan.
BeardedTexan
Feb 1, 2016 10:41 PM
vaper
Large Truck
Nov 18, 2015 09:17 AM
oldfatandtired
Large Truck
Jul 23, 2011 12:15 PM
richardchad
Jan 16, 2011 09:46 PM
chessman21
Apr 19, 2010 04:08 PM
