Hello all, blew out a tire today on my 1989 f700 4x4 dump. They are 10r22.5 tubeless tires. I misjudged the loader bucket and ran one of the teeth thru the sidewall where it meets the tread. This in an off road truck and will probably never see the road. I'm looking to fix or replace as cheap as possible. Can a patch be vulcanized in, or can a tube be installed, or just replace the tire. Thanks, Dave
Through the sidewall = buying a new or used tire is probably the best way to go.
I thought "sectioning" tires was a thing of the distant past, as my old man complained bitterly 40 years ago about not being able to get tube-type 9.00x20s sectioned. But I did a search:
A tube might be the way to go, but that puncture needs to be cleaned up and make sure you don't have a jagged hole or wires from the steel belts poking in there to pop the tube.
If you have a tire shop do this, you will probably have to convince them one way or another it's off road only.
your sidewall can be repaired , check for any INDUSTRIAL shops that can SECTION A TIRE ! you can also put a large patch , boot on the inside and then run a tube , there are different ways to do it your self if it is to be used off road ! 1 thing we use to do to tractor tires was to cut out a piece of from a old junk tire and glue it on the inside and then drill holes and put carriage bolts threw them with big washers on the outside and then lots of duct tape over the patch to smooth it out then put a tube in it , they were for slow speed use and off road !
As has been said you could have them section the tire, but you will have to stand by the fact its off road only. That means towing the vehicle in on a flat or taking its tire to them, then you having to replace it yourself after they repair it. Under no circumstance let that tire touch roadway.
Well I ended up patching the tire and it held. It had about a 2" slice inside the tire, I just inflated to 60 psi as opposed to the 100 psi required. The truck never gets out of 1st or 2nd gear so no problems if it blows out.
