Cetane ratings and fuel brands
Old May 19, 2011 | 07:03 AM
Biggziff's Avatar
Biggziff
I've looked a little, but haven't been able to find anything that shows which, if any, fuel brands generally have a higher cetane rating. Any ideas?
Old Sep 5, 2014 | 10:46 PM
RM2738's Avatar
RM2738
Curious as well.
Old Sep 5, 2014 | 10:59 PM
Jakebrake's Avatar
Jakebrake
< Samantha...my Co-Pilot
In North America, most states adopt ASTM D975 as their diesel fuel standard and the minimum cetane number is set at 40, with typical values in the 42-45 range. Premium diesels may or may not have higher cetane, depending on the supplier. Premium diesel often use additives to improve CN and lubricity, detergents to clean the fuel injectors and minimize carbon deposits, water dispersants, and other additives depending on geographical and seasonal needs.[citation needed]. California diesel fuel has a minimum cetane of 53.[3]
-Wikipedia
I have never seen cetane numbers posted in any of the states I have bought fuel. I have purchased Premium Diesel in the Seattle, Washington area but there was no posted cetane rating.
Old Sep 6, 2014 | 02:42 PM
RM2738's Avatar
RM2738
I found this.
BP (Amoco branded), 51;
Countrymark fuels Diesel-R, 50
Chevron, 49; or 51 with Techron D labels in select markets
ConocoPhillips through the 76 stations (California) 47-53
PetroCanada, 47-51
BP (Powerblend 47, otherwise 40-42)
Shell, 46;
Sinclair, 46;
Sunoco Gold, 45 (often +1-5) Sunoco regular is usually 40.
Exxon/Mobile, 43-46
Holiday Stations, 40-43
HESS, 40-42, can be up to 45.
Husky, 40 + diesel Max additives raise another 1-3 from there (41-45 max)
Love's: 40
Pilot: 40
Valero: 40
Sheetz: 40
Flying J, 40
Wawa, 40
Old Sep 6, 2014 | 04:47 PM
Misky6.0's Avatar
Misky6.0
Most stations in FL do post 40 as the MIN Cetane
Old Sep 6, 2014 | 06:21 PM
kper05's Avatar
kper05
Originally Posted by RM2738
I found this.
Good find. I was looking for that post here but couldn't find it after looking through a few fuel threads.
https://www.ford-trucks.com/forums/9...ml#post9335294
Old Sep 9, 2014 | 06:58 AM
Nearly Normal Mike's Avatar
Nearly Normal Mike
Cetane number
What is lowest recommended minimum cetane for stock new truck? I am new to all of this and after a discussion with my friendly bulk fuel dealer I feel compelled to add a dram or two of cetane booster to each tankful. It that a good idea?
I do what the local farmers reportedly do for their equipment and they use a LOT of diesel fuel!
I think I will do the same for my small (45hp) hobby farm tractor unless anyone has any better ideas. My tractors have always run fine on plain old bulk off road fuel.
Your thoughts? (I have always run Chevron gasoline in my cars.)
Nearly Normal Mike
Old Sep 9, 2014 | 07:29 AM
RM2738's Avatar
RM2738
The minimum Cetane rating for a 6.7L is 45.
Old Sep 10, 2014 | 08:25 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Nearly Normal Mike
On our farm we use a premium diesel with 50 cetane. Our supplier sells a lot of it. It burns clean and has great power
EpicCowlick
6.7L Power Stroke Diesel
65
Feb 28, 2020 09:15 PM
speakerfritz
General Diesel Discussion
Nov 18, 2016 04:02 PM
cowboyacg
Jul 19, 2016 12:51 PM
Firekite
69
May 21, 2016 10:25 AM
John with beastly 302
Sep 13, 2010 01:58 PM
