Onboard air, airbags, horns - complete
Been saving up a bit to get my air project up and running and finally managed to get it (mostly) done.
I picked up a Viair 10007 system, some Ride Rites (from a board member that purchased but decided against installing), and a Shocker XL train horn set.
I watched and re-watched the air bag video
https://www.ford-trucks.com/forums/1...ion-video.html(thanks much Epic!) and read the posts by Ruschejj
https://www.ford-trucks.com/forums/9...ir-system.html and chose to put the compressor and tank on the passenger side just behind the cab. I couldn't accept the tank mounting on the side because I know my faults and I know that I'd never unbolt it just for draining, so I had to adapt a way mount it with a drain at the bottom. I picked up some thick L brackets, mounted them to the frame rail, then mounted the compressor to the brackets.
The install was a bit bumpy with some minor issues. The Viair pressure switch was bad but the company had a new one on my doorstep the next day (kudos for customer service). The Ride Ride kit had a lock washer that made install quite impossible due to the large split. Eventually I cranked down on it with a vise and heated it up with a torch to shrink down the split and got it to work.
I wanted as clean/stock look install as I could so I wired the compressor to Upfitter 1 and used a relay to wire Upfitter 3 for the horns. With the switch off it's just my regular horn, with the switch on it sounds both (at least I think it does, no way to actually hear the stock horn over the air horns). No seperate switches and I can turn it off as needed.
I'm not happy with the gauges yet as they are installed just like Ruschjj did, but I'm going to brainstorm something that will give a little cleaner look and maybe take a little less space. I need to get a bit more of the wire wrap and clean up my relay install wires, but otherwise I'm all set.
The compressor is relatively quiet, the airbags inflate in ~20 secs, and the horns sound amazing (and a bit scary even when I know I'm about to hit em).
Thanks sooo much to those that provided posts with advice, pictures, and videos. It helped a lot
Horns are great, right? It's cool to honk back at trains......
Instead of running a hot wire to the battery for the compressor and another wire to the Upfitter, I spliced the hot and switched lines at the tank pressure switch and ran them to Upfitter#1 (yellow). The compressor specs show a draw of 19 amps and Upfitter#1 is rated for 25A so I saw no need to run a seperate hot wire to the battery.
I bought a 30 amp relay at Radio Shack (~$6) and wired it to the #3 upfitter (Violet w/green 10A). I tapped the stock horn wire (yellow with red trace) under the hood. There are numbers stamped into the relay and I wired it as follows
30 - Upfitter#3
85 - Ground
86 - Ford Horn - Yellow
87 - Air Horn Solenoid
Hope this helps =)
I'm going to be very cautious about when/how I use the horns so I don't get complaints, but when towing the big trailer I really need something better than that stock horn.
I wish I had video of demo-ing them for my wife. I blasted the regular horn 3 or 4 times and then hit the air horns. She knew it was coming and still jumped about 3 inches out of the passenger seat.
I'm in the process of creating a mounting bracket for the gauges that will clean up the install a bit (same location, just better fit). If it works out I'll probably be installing it tomorrow.
I was cutting grass at my son's school last night, tractor was leaning to the right, the right rear tire was way low on air so all I had to do was park by my rear bumper and fill 'er up.
Great stuff.
I am trying to figure out how to run all my plumbing for my air lines to set mine up similar to the way this thread was done by KG6EPF
I have the Viair 10007 kit installed (without gauge plumbed in, yet) and a set of Ride Rite bags, which is currently plumbed to the rear bumper for manual adjustment. I want to reconfigure mine to use the Ride Rite in cab single gauge/ controler and the Viair guage as well.
I am trying to understand how this will work before I buy the air horns and the Ride Rite gauge....
I only see two air lines in the pics coming into the cab...
- How is the plumbing setup for the in-cab gauges ?
- Did you "T" off the incoming line and run to both gauges (Viair and Ride Rite) ?
ALSO :
any problem with pulling the water drain and putting in a quick connect air hose fitting in.... I figure if I have any water in the tank it will run out the fitting when I connect an air line.
Any problems with this type of setup ??
Thank you for the help !
_
