A proposed Simple fix to most dual tank issues (illustration)
I've noticed a lot of people have had a ton of issues with this particular dual tank setup. I've had an idea about how to deal with it, but I'm not sure if it will work, so I thought I'd run it by others here for feedback.
What I'm thinking is to eliminate one in-tank low pressure pump (by disconnecting the electronics?) and also tossing the switching valve. Then connect the two tanks via a passive fuel line, letting gravity do its thing by keeping the two tanks at the same level. I'd rely on the fuel gauge in tank 1 to give me a level for both tanks.
Here's a diagram:
Do you guys think this will work? My guess is no, because it seems too simple.
I'll add that if you were to park on a steep hill, all of the fuel will eventually transfer to the lower tank, that is unless you have more than half full tanks. If that happens and the low pressure pump is on the high tank, you may not be able to start your truck due to no fuel at the low pressure pump.
The other thought is that to function properly the fuel transfer hose has to be at the lowest point, and just like on a over the road semi with a connect / transfer hose between the fuel tanks for just the purpose you propose, it is subject to snagging and road damage due to its low position.
Just food for thought -
David
If you park facing down hill, excess fuel will run into "tank 1", if you park facing up-hill, nothing will happen. If the hill was steep enough, I wonder if you would have fuel come out the filler neck on "tank 1".
You might as well do the bronco fuel tank mod and just eliminate the front tank if you dont want to switch back and forth. It would be a lot simpler.
I love this truck, but I absolutely hate the fuel tank set up and all of the easily broken parts.
BTW is that blue '50 yours? If so, VERY nice.
1983 Ford Bronco '84-89 Fuel Reservoirs pictures, videos, and sounds | SuperMotors.net
I picked up a spare DFR at the junkyard for $15 and will try this rebuild on it first. If it works, it will be alot better then paying $150-$200 for a new one if you can find one.
Thanks,that's my baby. If you wanna see more pics, check out: https://www.ford-trucks.com/forums/6...rucks-261.html
Quote:
<TABLE border=0 cellSpacing=0 cellPadding=6 width="100%"><TBODY><TR><TD style="BORDER-BOTTOM: 1px inset; BORDER-LEFT: 1px inset; BORDER-TOP: 1px inset; BORDER-RIGHT: 1px inset" class=alt2>Originally Posted by BPofMD
Morning world !
Howdy Junior......hope this is a paying job!
Charlie.... how do you know that BOTH pumps went south??? Seems weird to me to have BOTH go out at same time! Sounds more like you lost elect to both at same time. I know you are usually pretty through in diagnosing problems, but......
</TD></TR></TBODY></TABLE>
this truck has 2 lift pumps, and a main high pressure pump.In the middle is a transfer switch, that closes off when the other tank has pressure against it. Back tank flap up, front tank flap down. No pressure, flap stays where ever it was last time it had pressure. Now for the fun part. when a pump won't run, the high pressure pump acts like a siphon pump, until the tank equilizes pressure, or fuel becomes level with the pump, then it quits. SOOOOOO, back to your question, yes, both pumps are bad, because,
1. key cycled, and listening in fill cap, both tanks, no pump noise heard
2.back tank ran out at 1/4 tank, which would be level with pump
3. switch was on front tank,guage was reading full, back tank ran out, so flap was in the up position, high pressure pump was drawing off back tank.
on a good note, I pumped the front tank out into 5 gal buckets, dropped it, put in the new fuel pump, put it back up, filled it, and it is pumping off the front tank. I have to drop the spare, and the class 3 hitch to get the back tank out, so that will be later in the week.
<!-- / message --><!-- sig -->__________________
On my more recent 1990's (different system, only two pumps - which is why I decided to go to the 1990 model year, well that and the availability of a EFI big block), and while they also can have the fuel return issue, I have had zero problem with either of them, although I have only owned two, a recently traded in 1990 and still have one. The 1990 Bronco that I have doesn't count since it only has one tank )
Perhaps I am luckier than most, I certainly see the potential for problems, and even Ford has covered this issue, but it is not one that I am concerned with, given my personal history with the trucks.
I have given the Bronco tank a serious thought, if only there was something to do with the spare tire, but to me havving that in the way out front or in the box taking up valuable cargo space just did not give me the benifits that i was looking for. Perhaps, now with fuel prices going up, I could add the Bronco tank in addition to my front tank, and I might save some money in the run due to the almost daily price jumps!
Lots of good ideas on work arounds none the less!
David
Here's a diagram:
