Intermittent at times 6.0l
My 03 6.0l runs great most of the time, but at times it sounds like it's struggling a bit, not sure if it's a case of the EGR fever or what, the dealer told me that the egr gets a build up of carbon (soot) and you need to "drive it like you stole it" lol. So I triy to floor it and clean it out and it really dont seem to help. Changed fuel filters, running Motorcraft additive as well, 4x the recommended amount on bottle as the dealership says to. So my plan is to install the egr delete but I'm not sure if it's a job I can do myself, as the dealer will not install it due to legal issues apparently? So I guess if anyone has any input about what may cause the "struggling" like behavior or advice about the delete kit, this would help a lot! Thanks
I had the same problems, intermitten at Idles at times and jurking at around 1500 to 1700 RPM on highway, at times, not all the times.
I am at ford dealer in Savanah right now and they are replacing my IPR, internal pressure regulator. The tech says it might have a piece of dirt in there. It is still on waranty, so we will see later on.
I also had the oil changed, I had 0 W 30 synthetic for north Canada, and now in south, they put in 15 w 40 but that did not make it. I also had ICP replaced and Map Sensor replaced, which did not fix the problem.
I drove 100 miles today plus some town driving. The surging did not come back,,,, yet. The mechanic said it had some debris, which debris, I do not know. Anyway, I will drive another 150 miles sunday and see what happens.
The stupid engine light came back on, but that's an old story, it comes on at times. I bought a scangauge today and will install tomorow to check the codes, but so far the engine runs fine, no problems at all.
![Jammin](images/smilies2/party0031.gif)
Are you basing this from the whistle sound? Or from a boost gage? I sometimes think I hear the same thing, but its hard to tell with all the external noise.
Originally Posted by kidoo
Going for another 120 miles today. I cleared the CEL yesterday with scangauge.
I would like to know the negative effects of unplugging the egr? Also what reasons could there possibly be for having an egr? So why not install the delete kit??? Egr valves are a stupid invention to supposedly get rid of excess "nitrogen oxides" so they say, but all the problems they cause deem them ridiculous in my book.
Do your homework. Unplugging the egr valve makes the fan not operate the correct way. This was a recent finding by one of the techs that is on here (cheezit), he was playing around with the IDS and noticed this. That's my reason. people thought for years "just get rid of the egr system it's junk and won't hurt anything not being there." Now all of the sudden we find out about the fan operation being effected. What will we find out next. Now i'm not saying that a delete is completly bad, just that I (along with many others on here) don't really recomended going that route. Instead, IF (yes I said IF not when), your EGR cooler goes out just install a BPD one. They have had very little to no failures. I my self went 140~k miles with never having a EGR issue. Yes, I do have a delete installed on mine, but the only reason is I bought into all the hype. Plus that was before we found out about the fan operations. I plan to install a bullet proff one. I do still have my EGR valve in place and pluged in.
