Battery/Amp gauge for the 6.7
If you are serious about gauges, make up your mind on several things:
- how many points do you want to monitor volt / amps at?
- do you want mechanical / electronic gauges
- where are you going to put them?
What's the OBD port and where is it?
What's meant by points to monitor?
Type of gauge, whatever is best
Where to put it, don't have a clue. I reckon I'll find someplace.
I just think you need something to tell you if your charging, discharging, or whatever.
There is no such thing as ignorance when you ask questions!
The port is right underneath the steering wheel on the kick panel --- look for it.
It is covered but you can open the cover to reveal an industry standard OBD II plug.
Then you can get a standard monitor tool like Scangauge II (or any other similar one) to read more data than you ever want to know:
ScanGaugeII - Trip Computers + Digital Gauges + Scan Tool
You can set it to read voltage, and do neat things like have it sound an alarm if voltage is too low (you set).
I don't think it reads amps.
If you are talking about installing volt and amp gauges, that is very complex --- I advise you not to do it if the Scangauge does the trick.
Sometimes, the easiest solution is the best.
You don't risk a short, blowing something up... etc.
In the good old days, we installed ammeters that are mechanical --- there are outfits that now sell both mechanical and electronic monitors.. but they cost $$$ and time to install.
If you use the voltmeter properly, it will not need an ammeter.
But if you really want one... here is something to read:
http://www.stuttgartperformanceengin...veammater.html
