FAQ - Axle Code Charts
-ct 10-Feb-2011
I have been looking at a few 1980's trucks for sale around here, but am often unable to determine the axle ratio and weight rating. I searched a couple times, but found nothing.
Could someone please post the axle code chart for the 1980-1986 F250 and F350 trucks and identify what year manual the chart was taken from? It would be greatly appreciated.
My expertise is 1967-1979 trucks, and that is all I have manuals for...
01 = Ford 9" - Capacity 2800 - Ratio 2.75
02 = Ford 9" - Capacity 2800 - Ratio 3.00
04 = Ford 9" - Capacity 2800 - Ratio 3.25
07 = Ford 9" - Capacity 2800 - Ratio 2.47
13 = Ford 9" - Capacity 3750 - Ratio 2.75
14 = Ford 9" - Capacity 3750 - Ratio 3.00
15 = Ford 9" - Capacity 3750 - Ratio 3.25
16 = Ford 9" - Capacity 3750 - Ratio 3.50
17 = Ford 9" - Capacity 3750 - Ratio 2.47
H3 = Ford 9" Limited Slip - Capacity 3750 - Ratio 2.75
H4 = Ford 9" Limited Slip - Capacity 3750 - Ratio 3.00
H5 = Ford 9" Limited Slip - Capacity 3750 - Ratio 3.25
H6 = Ford 9" Limited Slip - Capacity 3750 - Ratio 3.50
H7 = Ford 9" Limited Slip - Capacity 3750 - Ratio 2.47
37 = Dana 60 - Capacity 5300 - Ratio 3.54
38 = Dana 60 - Capacity 5300 - Ratio 3.73
25 = Dana 60 - Capacity 5300 - Ratio 3.33
B5 = Dana 60 - Limited Slip - Capacity 5300 - Ratio 3.33
C7 = Dana 60 - Limited Slip - Capacity 5300 - Ratio 3.54
32 = Dana 61 - Capacity 5300 - Ratio 3.00
C2 = Dana 61 - Limited Slip - Capacity 5300 - Ratio 3.00
42 = Dana - Capacity 6250 - Ratio 3.73
43 = Dana - Capacity 6250 - Ratio 4.10
44 = Dana - Capacity 6250 - Ratio 4.56
41 = Dana - Capacity 6250 - Ratio 3.54
D3 = Dana - Limited Slip - Capacity 6250 - Ratio 4.10
36 = Dana 70 - Capacity 7400 - Ratio 3.73
27 = Dana 70 - Capacity 7400 - Ratio 4.10
28 = Dana 70 - Capacity 7400 - Ratio 4.56
D7 = Dana 70 - Limited Slip - Capacity 5300 - Ratio 4.10
51 = Dana 70 HD - Capacity 7400 - Ratio 3.73
52 = Dana 70 HD - Capacity 7400 - Ratio 4.10
53 = Dana 70 HD - Capacity 7400 - Ratio 4.56
E2 = Dana 70 HD - Limited Slip - Capacity 7400 - Ratio 4.10
62 = Dana - Capacity 8100 - Ratio 4.10
Front Axle Code = 2 = Front Axle Limited Slip.
Hope This Helps
13 Ford 3750 4.11
14 Ford 3750 3.00
16 Ford 3750 3.50
17 Ford 3750 2.47
18 Ford 3750 3.08
19 Ford 3750 3.55
22 Dana 5300 4.10
23 Dana 5300 3.54
24 Dana 5300 3.73
25 Ford 5300 4.10
26 Ford 4050 3.55(8 lug 8.8?)
27 Ford 5300 3.73
29 Ford 5300 3.55
31 Dana 6250 3.07
32 Dana 6250 4.10
33 Dana 6250 3.54
35 Ford 6250 4.10
38 Ford 6250 3.08
39 Ford 6250 3.55
72 Dana 6300 4.10
73 Dana 6300 3.54
42 Dana 7400 4.10
43 Dana 7400 3.54
45 Ford 7400 4.10
49 Ford 7400 3.55
52 Dana 7400 4.10
53 Dana 7400 3.54
62 Dana 8200 4.10
63 Dana 8200 3.54
65 Ford 8200 4.10
69 Ford 8200 3.55
Limited Slip:
H3 Ford 3750 4.11
H4 " " 3.00
H6 " " 3.50
H8 " " 3.08
H9 " " 3.55
B2 Dana 5300 4.10
B3 " " 3.54
B4 " " 3.73
B5 Ford 5300 4.10
B7 " " 3.73
B6 " " 3.55
C2 Dana 6250 4.10
C3 " " 3.54
C5 Ford " 4.10
C9 " " 3.55
G2 Dana 6300 4.10
G3 " " 3.54
D2 " 7400 4.10
D3 " " 3.54
D5 Ford " 4.10
E2 Dana " 4.10
E5 Ford 8200 4.10
F9 " 8250 3.55
You'll notice that some of the codes that are the same between the early and late books don't necessarily correspond when it comes to what axle they indicate. The same goes for alot of the current online decoders. Same code, different meaning.
And makes it confusing as heck.
