HOW DO I LOCK DRIVERS DOOR ON '61?
Old Feb 6, 2011 | 07:29 PM
Tennessee Toy's Avatar
Tennessee Toy
i tried by pushing inside door handle down. what have i missed?
i know they didn't put key locks on drivers door back then but how do i lock the door?
i looked in search and failed to find anything that covers the answer to this
Old Feb 6, 2011 | 07:31 PM
Broomfieldbum's Avatar
Broomfieldbum
I would look in the door for unhooked linkage, that is how you lock the door on a 61 as far as I know.
Old Feb 6, 2011 | 07:32 PM
Bill W's Avatar
Bill W
push the door handle the oppsite way of opening the door, that will lock it from the inside.
Old Feb 6, 2011 | 07:35 PM
Tennessee Toy
must have someting broke inside the door. i have tried going the opposite way.
where do i find these parts?
Old Feb 8, 2011 | 06:57 AM
charliemccraney's Avatar
charliemccraney
You have to lock the driver door, and get out through the passenger door. The latch mechanism prevents you from locking yourself out without the key. That is if you lock it with the handle, then shut the door, it will be unlocked.
If it just plain and simply will not lock, a linkage rod has probably been bent by some ham fisted user in the past. That rod is a part of the latch and difficult to repair; a replacement latch will be the easiest fix.
Old Feb 8, 2011 | 11:56 PM
Shorty 66's Avatar
Shorty 66
Step 1: get out of the truck and shut the door.
Step 2: insert key into lock cylinder.
Step 3: turn key oppisite way that you would unlock the door, and the door will be locked.
Old Feb 9, 2011 | 07:16 AM
gangstakr's Avatar
gangstakr
There is no key cylinder on drivers door on his truck.
Old Feb 9, 2011 | 11:00 AM
CropDusterMan's Avatar
CropDusterMan
What kind of smart-a$$ answer is that??! If you're not trying to help the guy,
why bother posting?
Hey Brian, pull the lower access panel and have a look up there with a flashlight...do you see anything out of sorts...?
It should be evident if so...
Old Feb 9, 2011 | 07:54 PM
Tennessee Toy
hey guys - appreciate the comments and helpful advice. i am a sales rep and unfortunately travel away from home all week. I will be back in on Friday and if weather permits i plan on checking into my problem.
thanks again - cropduster - i will re post when i see what i find.
Old Feb 13, 2011 | 06:11 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Left hand door lock cylinders were first offered on 1953 Custom Cabs as standard equipment. Prior trucks had none.
The left door lock cylinder was a factory installed option on Standard Cabs: 1953 thru 1962.
No left door lock cylinder: The idea was that automakers didn't want people standing out in traffic locking/unlocking doors, so most vehicles had none on the left until the late 1940's.
People locked the left door, then slid over the seat and exited the right side. Most streets back then had no painted divider lines, so traffic was chaotic.
1961/67: You push the inside handle forward to lock the doors from the inside.
The only way to lock these doors from the outside is with the key.
1968: Ford introduced door lock *****. To lock these doors, you push the lock **** down, then close the door holding the pushbutton on the handle...in.
Old Feb 13, 2011 | 08:06 PM
Carefree T's Avatar
Carefree T
Took me a while to figure it out myself, but charliemccraney is correct, provided your mechanism isn't broken. You turn the handle the opposite direction, then get out via the passenger side. If you do it then close the door, it will unlock. You have no choice but to exit and enter via the passenger's side door if you want your driver's side door locked. Again, assuming it isn't broken, obviously.
