Thanks for the reply. My 2006 6.0 diesel at times shows 3/4 tank then next time a full tank and then again it will not register any full level. Bad ground maybe?
More than likely a bad sending unit, but if you are in an area with a lot of road salt you might want to just check the connection for corrosion. Not much to it though.
