6.0 wiring
Old Jan 13, 2011 | 10:07 AM
dkcars's Avatar
dkcars
Exclamation 6.0 wiring
I need the wiring diagram for the fuel tank on a 06 F-350 6.0 dually, looks like it has a plastic fuel tank. Or maybe wrapped in a plastic shield.
Old Jan 13, 2011 | 11:29 AM
npccpartsman's Avatar
npccpartsman
Hmm........Nothing there but a sending unit--one plug at the frame. It can be a plastic tank but it does have a shield on the outside.
Old Jan 14, 2011 | 12:18 PM
dkcars's Avatar
dkcars
Thanks for the reply. My 2006 6.0 diesel at times shows 3/4 tank then next time a full tank and then again it will not register any full level. Bad ground maybe?
Old Jan 14, 2011 | 12:26 PM
npccpartsman
More than likely a bad sending unit, but if you are in an area with a lot of road salt you might want to just check the connection for corrosion. Not much to it though.
Old Jan 14, 2011 | 12:32 PM
dkcars's Avatar
dkcars
Thank you. Ill inspect the connection.
