HOWTO - 81-86 gauge cluster in 80 model (gauge models ONLY!)
This ONLY applies to trucks with full gauges, not the trucks with oil/alt lights!
As we have all heard, 1980 is a "One year wonder" in many aspects, and the cluster is one such aspect. The printed circuit for the 1980 models is green, and is wired differently than the 81-86, which is red. Otherwise, the clusters themselves are the same.
You can swap the clusters from a gauge equipped truck, into another gauge equipped truck at random in the 81-86 range, but the 1980 is a different matter. Or is it?
To install an 81-86 cluster into an 80 model, you need the cluster, and the dash bezel that surrounds the cluster. The upper row of lights (turn indicators, brake/seatbelt warning, and high beam indicator) was rearrainged in 81. Part of the wiring changes for these light relocations was made in the printed circuit, and the rest in the plug that goes into the back of the cluster. These wires can be moved, and it really doesn't take much effort.
The same can be done to install the 80 cluster into an 81-86. Swap the same 2 wires, and use the matching 1980 cluster and bezel. Not that anyone would really want that super bright high beam indicator......
FWIW, those 2 wires are the L turn indicator and seatbelt warning light. The R turn indicator and brake warning light are changed in the printed circuit.
As you can see, I have quoted ri_truck_guy for the wiring pinout changes. He did the research on this, using what I assume to be factory service manuals, at my request.
I had started a thread about installing a factory tach, and discovered the roadblocks to swapping the cluster in an 80 model.
You can read all about it here: https://www.ford-trucks.com/forums/9...-question.html
It's a rather long read, and the info is all there, but much harder to follow. So, I have summerized the important part here, to make it very simple to follow.
Rogue, it's been awhile since I played around with this, so I may be forgetting some details, but I could have sworn it was my right turn signal and brake light that were mixed around?
If the other signal and light were changed in the printed circuit, wouldn't they still be mixed up?
Using the 81+ bezel, and swapping wires 17/18 makes it true to 81+ specs.
1980:
[ 4x4*] [seatbelt] [L turn] [high beam] [R turn] [brake] [4x4]
1981-1986:
[blank*] [L turn] [seatbelt] [high beam] [brake] [R turn] [4x4]
This is why the wire swap and newer bezel are needed to make the full upgrade to 81+ cluster specs. 1980 models are much harder to find in a salvage yard than the 81-86, due to limited production. (1 year vs 6 years)
* 1980 had 4x4 on both sides, but only the right side was used on north american 4wd models. Perhaps it was there for the right hand drive market. Beyond my knowledge.
1981-1986 The "blank" could be a black plate, an orange "shift" light, or an orange "emmission" light. depending on year and options. Shift light for certain manual trans models, and emmission for certain computer controlled models. There may have been something else that could have been there that I'm not aware of.
The 4x4 and shift/emmission lights were wired independant of the main cluster using seperate sockets, thus they are not important to mention in the main writeup.
As mentioned, the right turn and brake warning were wired differently on the printed circuit, and cannot be rewired. The red/green lens can be removed and moved, but can be difficult to do, and they can be rather fragile to handle. I recommend leaving them alone, except as a last resort. The 81+ bezels are much more plentiful, and are perfect swap by moving wires 17/18.
Swapping 15/16 will not move the lights in the dash. It results in one that stays lit anytime the key is on, and one that never lights up. Ask me how I know.......
I believe the right turn/brake lights are the only *actual* changes between the green 1980 and red 81+ printed circuits, as far as gas models are concerned. Granted, there's at least 2 variant's of each for with/without tach.
For fun, here's a pic of a green 1980 non/tach printed circuit. Everybody keep in mind that in summer 1980, 1981 production started, so trucks built after July 1980 will have red printed circuits.
BTW, thanks for the research you did when I needed it. Without your assistance, I wouldn't have been able to make the swap sound so simple (which it really is).
