hey guys was thinking of running a oil line from the front to the back on a 351m but heres what i dont get where two hook it up at the back some pics of it shows it run to the top where the sending unit is and others show it run to the back of the engine but if i go to the back how do i clear the trany --thanks
The hole for the oil sending unit is 1/4". Get a 2 way block (available at auto parts stores) and screw it into your motor there that way then you can run your hose and still have a connection for your oil gauge. I'm going with Russell hose, they have 90 degree and 45 degree hose connectors. They also have AN to pipe thread adapters for the fittings. The fitting you will need to use for the front of the motor is 3/8" (next to oil filter). I'm going to use 90 degree hose ends with 06 AN hose, so with the block on top of the motor and the 90's I can basically aim the hose in any direction. I even contacted Russell and they said their hose was compatible for oil and had a burst rating of 1000 psi.
Well believe it or not there is a lot of room behind the flywheel to hide the line. This does require you to drill or grind a hole thru the block and then route the lines to one of the oil plug galleys that are under the flywheel..
Note this also works great for hiding NOS lines to the intake and plumbing the Intake from the underside . I seen this in a HotRod Mag. many years ago done on a Small Block Ch**Y....
That was back when the Clevelands where allowed to race.
The oil line trick has been debated for years and not done nearly as often anymore. It's definately not needed for a mild street application. The restrictors are another story.
You are suposed to use a bulk head and nut to go through the back of the block. From there I bend up a piece of steel tubing and then connect it to the port with a -4 to 1/8 pipe 90°.
I anyone is looking for these I work for a company that should be able to sell them to you
Well, with the rebuild I have planned for the future , I might as well go with the Melling HV. Looks like plenty of room under the hood for a cooler. I'm even thinking of relocating the oil filter. (if they even make a by-pass for the 335 series)
Can I still go postal if I don't have enough stamps?
