identify head type in photo
Old Oct 22, 2010 | 12:08 AM
F-250 restorer's Avatar
F-250 restorer
I have a head I pulled from an 81 F250. It has ridges that you can see below, around the bottom half of the valves.
Can anyone identify it? Of course I will run the numbers, but thought someone might be able to identify from sight. I haven't seen anyone else with chambers like this. Doesn't the EFI head have these ridges?
<a href="http://s659.photobucket.com/albums/uu316/bobbyrogue/?action=view&current=P1010114.jpg" target="_blank"><img src="http://i659.photobucket.com/albums/uu316/bobbyrogue/P1010114.jpg" border="0" alt="chebby valves in a FORD??"></a>
Can someone tell me where the factory #s are located?
Old Oct 22, 2010 | 07:09 PM
F-250 restorer
Can't someone identify this head and tell me why the ridges are there?
Old Oct 23, 2010 | 07:07 AM
flipklos's Avatar
flipklos
My guess is a 240 head. Some #s and date codes would be handy.
Old Oct 23, 2010 | 01:39 PM
F-250 restorer
If I remember correctly, the Ford stamp is behind the thermo. housing, inside the v. cover. Is that right?
Flip--I thought the 240 chambers were peanut shaped.
I had to check my own files, and found this: : 240 head id
Under the stat outlet - the third letter should be an "A" - such as C5AE. Also, the chamber had a distinct kidney bean shape.
Old Oct 23, 2010 | 08:47 PM
flipklos's Avatar
flipklos
The casting # is inside the rocker valley somwhere.
C5AE translates as 1965-Ford-Engine.
A proper # would be more like C5AE-6015-B.
Those combustion chambers look kinda peanut shaped to me with the shrouding and all.
I also think that the # may be cast into the flange over the intake/exhaust ports.
Old Oct 24, 2010 | 12:37 PM
F-250 restorer
Thanks Flip--
Once my back gets better I'll pull the v.cover and post the #s I find. I should have run them when I pulled it, but due to lack of experience, I just assumed that a head on a 81 must be an 81. Boy was I wrong.
I have searched all around the outside, and can't find any #s.
Old Oct 24, 2010 | 01:08 PM
flipklos's Avatar
flipklos
Heal up well. Keep me posted on what you find.
Old Oct 24, 2010 | 03:30 PM
dustybumpers's Avatar
dustybumpers
the number is on the right, under the thermostat housing. the head kinda goes back there before it hits the block, and you may need a mirror to see it if it is still on the block. that is not an efi head. if you need pics, let me know, I have a couple of heads here.
