1994 - 1997 Ford Pickup Truck Valve Cover Gasket Repair Kit with Dual Injector
![](http://www2.1aauto.com/_include/gui/logo_large.gif)
1994 - 1997 Ford Pickup Truck Valve Cover Gasket Repair Kit with Dual Injector & Glow Plug Harnesses for Models with V8-445ci 7.3L Diesel
This valve cover gasket set is just the kit you need when you are planning to replace a leaky valve cover seal with a malfunctioning fuel injector & glow plug harness. The set contains the gasket and injector/ glow plug harness that is needed to replace the valve cover to the cylinder head and put an end to leaky valve covers or a malfunctioning injector harness.
This valve cover gasket repair kit has the following specifications:
Made from high quality materials
Heat resistant
Oil resistant
Direct replacement
Built to strict quality control standards
Specific to the Ford 7.3L Diesel Engines with direct injection
Includes everything to do the job right the first time!
This valve cover gasket set contains the following pieces:
Valve cover gasket with dual integral fuel injector connectors - Qty (1)
Inner Injector/ glow plug harness with correct plugs - Qty (2)
Originals are regularly damaged during repair
Original glow plug connectors fail due to excessive heat
Correct outer connector plug with pigtail harness for splicing if needed - Qty (2)
Note: For 1998 models you can find the production date of your vehicle on either the outer edge of the driver's front door or on the latch piller that the door closes on.
