Help!!!
Old Oct 9, 2010 | 10:30 PM
C350CREW's Avatar
C350CREW
Help!!!
I was just working on replacing all the orings on the fuel bowl and just broke a small piece out of the bleeder orifice. Where can I get one??
I also need a heater element? How necessary is this?? Can it be re attached?
Old Oct 9, 2010 | 10:48 PM
mq1shooter's Avatar
mq1shooter
Replacement O-rings for Ford Diesel Engines
I bought mine from the dealer...think a lot of guys might not use them much, guess it depends on your weather and fuel blending. But others with more knowledge will chime in soon...
Old Oct 10, 2010 | 05:02 AM
tjbeggs's Avatar
tjbeggs
Don't worry about the fuel heater. I haven't had one hooked up in the 6 years I have owned a PSD up here in Michigan. Its not needed. BUT on the orifice I think about the only way you are going to get that is from Ford but they may tell you the only way its available is with a whole new fuel bowl but try these numbers with them
Fuel Pressure Regulator Screen Kit (Orifice Vent Kit) Includes screened plug, o-ring, check valve
(Ford) F6TZ-9150-AA Screen and o-ring kit
(Ford) F5TZ-9A214-A ??? KIT-VENT ASY -DUAL
Old Oct 10, 2010 | 06:00 AM
FARM69's Avatar
FARM69
If you decide to run with the broken heater element make sure you unplug it from the side of the housing. The engine doesn't like it when it shorts out...
Old Oct 10, 2010 | 06:24 AM
427 fordman's Avatar
427 fordman
I'd check with edthepartsguy with the numbers tim posted unless your local dealer is smarter than mine...
Old Oct 10, 2010 | 10:10 AM
C350CREW's Avatar
C350CREW
Thanks, for the info. Once again saved by u guys.
