need help
Old Oct 9, 2010 | 08:56 AM
1986ford150's Avatar
1986ford150
need help
I have a 1986 2wd f150 300 six. How much work would it be to convert it to 4wd!
Old Oct 9, 2010 | 09:10 AM
ctubutis's Avatar
ctubutis
About as difficult as disassembling the entire front suspension and then reassembling it
using never-before-worked-with components, and adding a transfer case to the tranny, and
having the original driveshaft shortened, and cutting a hole in your tunnel for its shift lever.
Some guys out here will say it's easy as snot; if I were to undertake this, I'd allocate at
least a month's worth of weekends (assuming I already had all the parts).
