IPR question - torn screen (pic
Old Oct 8, 2010 | 06:39 PM
amgpro2's Avatar
amgpro2
I started to take the HPOP out and removed the IPR. The IPR screen is torn. Since the dealer just replaced my oil cooler should I open it up and check the screen below the oil cooler? Does a torn ipr screen result from a torn oil cooler screen? Can I just take apart the oil cooler and reuse gaskets? Any help would be appreciated.
http://i283.photobucket.com/albums/k...mg_pro/IPR.jpg
<a href="http://s283.photobucket.com/albums/kk288/amg_pro/?action=view&current=hpop.jpg" target="_blank"><img src="http://i283.photobucket.com/albums/kk288/amg_pro/hpop.jpg" border="0" alt="HPOP &amp;amp; IPR"></a>
Old Oct 8, 2010 | 06:53 PM
m-chan68's Avatar
m-chan68
A torn IPR screen usually means some foreign debris made its way through the passage under oil cooler. This is the very reason it is crucially important to use a blow gun to blow off any and all surrounding debris before removing the oil cooler so that nothing falls in. I see you still have your STC fitting. NOW, would be the time to install the update one-piece branch tube connector.
Old Oct 8, 2010 | 06:59 PM
amgpro2's Avatar
amgpro2
Thanks m-chan68,
The IPR screen has sand caught in it. I know they did not clean out the valley because even though I pressure washed the engine before I started my tear down there was still sand left in there. I suspect the sand has gone thru. Will it/has probably scarred the injector oil side?
Here is a shot of the old worn down unison ring. In your opinon should the tech have advised me on replaceing it? Would you have put it back together with this amount of wear?
<a href="http://s283.photobucket.com/albums/kk288/amg_pro/?action=view&current=unison.jpg" target="_blank"><img src="http://i283.photobucket.com/albums/kk288/amg_pro/unison.jpg" border="0" alt="Unison Ring"></a>
Old Oct 8, 2010 | 07:06 PM
amgpro2's Avatar
amgpro2
I did buy the updated STC kit. I have the classic no start hot issue and was taking the HPOP out for this very same reason. Got the stand pipe kit that IRC you recommended that comes with both tubes and dummy plugs. Just ran into this ipr issue though.
Old Oct 8, 2010 | 07:13 PM
cheezit's Avatar
cheezit
ipr damaged more then likly caused by improper cleaningf around oil cooler befor removal. some times no matter how much we clean it still happens.
the unison ring should be replaced. they are available.
Old Oct 8, 2010 | 07:19 PM
amgpro2's Avatar
amgpro2
Thanks Cheezit, I did buy a new when I saw how worn this one was. I am waiting on a rebuild kit for my turbo to put it all back together. Here a pic.
<a href="http://s283.photobucket.com/albums/kk288/amg_pro/?action=view&current=turbo.jpg" target="_blank"><img src="http://i283.photobucket.com/albums/kk288/amg_pro/turbo.jpg" border="0" alt="Turbo"></a>
Can I take oil cooler out and reuse gaskets if everything checks out?
Old Oct 8, 2010 | 07:52 PM
amgpro2's Avatar
amgpro2
Damn, I just openned the STC kit (4C3Z-9B246-F) and noticed it came with a new IPR screen tip. Just after I had ordered a new Ford IPR from ebay for $103. Just putting this out there so other can learn from my mistake.
Old Oct 8, 2010 | 07:54 PM
cheezit's Avatar
cheezit
odds are you are gonna need the new ipr. I dont think a screen will fix it. the screens work great if there sucked in or restriced. no so great when the screen has a hole in it.
AGP
Jan 20, 2017 06:48 PM
AGP
Jun 7, 2016 11:47 AM
saz2686
Modular V10 (6.8l)
17
May 16, 2014 03:24 PM
saz2686
Dec 29, 2012 05:32 PM
amgpro2
Oct 10, 2010 07:11 PM
