Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Upper A arms
Old Oct 8, 2010 | 05:04 PM
$Bruiser$'s Avatar
$Bruiser$
Upper A arms
So I need to change my upper A arm bushings, only I am not to sure how to do this, do I do this with the front end lifted or with load on the wheels? Do I need to worry about the front springs at all?
Oh and I am just changing the upper A arm bushing and nothing else, thanks.
Old Oct 9, 2010 | 12:17 AM
Fomoko1's Avatar
Fomoko1
What suspension are you inquiring about?
Old Oct 10, 2010 | 01:51 PM
Snowking's Avatar
Snowking
Yep not quite sure what your talkin about. But in most cases easiest to remove front sheet metal.. And just jack enough to take the weight off but not too high.
Old Oct 10, 2010 | 04:18 PM
$Bruiser$'s Avatar
$Bruiser$
It is on a mustang II front end, I accually did one side so far this weekend and it went ok, alot of work for a couple little bushings but it needed to be done, I hope to tackle the other side soon.
