So I am gathering information for my new build. I found an 89 ford club wagon 1 ton with a 460 in it. I wanted to know if anyone has used this method or is the van chassis not needed, truck frame maybe? I want to keep the motor in front. I also found a diesel 2003 e450. I might use this as a tow vehicle. So I need help deciding on a frame. thanks
Sounds interesting, what year COE do you have? Any pictures?? we love pictures!
I have heard of a lot of Ch>ey P30? or was it p20?? stepvans being used for a donor chassis for Coe's as well as lots of different RV's Not so sure on what ford Chassis out there might be good candidates?? I think the biggest advantage of the Rv's and Stepvans etc is that the steering setup is already there and needs minimal rework to use. ??
That is a great looking truck! looks pretty solid too!
Lots of Ford powered RV's out there too? not sure about the van but am sure it could be made to work. how long of chassis are you looking at needing? Engine in original location or move behind cab?? will a 460 fit under the original doghouse?
The ford rvs are based on truck chassis. I'm planning on a 03 or the 06 I'm looking at one has a 7.3 the other is a 6.0 diesel of corse. E450 they are both tram type vans, you know the ones that carry people at the airport. I beieve the house needs some trimming I'd like it sitting low with out lots of suspension lowering if any at all
you can put the coe on anything, nothing is impossible just take it a piece at a time and render a great ride, keep us posted on the progress, Garry
I should know by next week what van i'm going with. It is between a 89 e350 with a 460 in it, or a 01 e450 dually with the 7.3 turbo diesel. all depends, do I want it low with a custom bed, or kinda low dually with a dove tail bed
