Head Gasket
Old Oct 7, 2010 | 06:43 PM
WyldeF250's Avatar
WyldeF250
Head Gasket
1969 Ford F250, 360 V8
Did an oil change a few weeks ago. Checked the oil dipstick yesterday and found coolant in the oil. Figure it's a Head Gasket problem. Engine runs strong after it warms up, but it won't pass Nevada smog yet.
Before I tear apart the engine, does anyone have any experience with products like Steal Seal? Or similar products that claim to seal the head gasket with out tearing apart the engine?
Old Oct 7, 2010 | 06:53 PM
arctic y block's Avatar
arctic y block
Don't know about that product but others I have used can plug up the heater core, radiator, water passages and damage the water pump an so on. It's better to fix it right the first time.
Old Oct 7, 2010 | 06:59 PM
CougarJohn's Avatar
CougarJohn
Don't jump to conclusions. Do you see steaming on the exhaust? Any bubbles in the radiator? What do the plugs look like? Compression test? Has the engine been overheated? Frozen?
Oil can get into the crankcase through other paths like an intake manifold gasket.
The pros will be in soon. There are a lot of smart guys who know all about those motors. Don't panic.
Old Oct 7, 2010 | 07:54 PM
4x4jedi's Avatar
4x4jedi
I just had the same thing happen. I needed to pull the heads anyway to get my headers on anyway so I got a complete motor gasket kit for $150. I had steam one day but it was also humid and rainy. It didn't do too good on comp test so I opened her up. Got everything back together and it seems like it wasn't a gasket. I must have a crack somewhere. Still have tiny bit of coolant getting into my oil and visa versa.
God knows what it could be in your engine though.
Old Dec 4, 2010 | 08:02 PM
Tonygentile's Avatar
Tonygentile
My exhaust is white and I have coolant leaking. My head is for sure blown right ?
I have a rebuilt 390. Any thoughts on what I should do at thisAny help would be much appreciated.
Old Dec 5, 2010 | 05:38 AM
60F100's Avatar
60F100
Do a compression test. see if you can locate which cylinder it is.
Old Dec 5, 2010 | 04:09 PM
CougarJohn's Avatar
CougarJohn
With the symptoms that you describe, you are going to have to pull the heads. Make a budget for a valve job and gaskets. The shop will check the heads for cracks.
Sorry, there is no other way.
Old Dec 5, 2010 | 09:31 PM
CropDusterMan's Avatar
CropDusterMan
I don't feel there is any substitute for the proper gaskets...all those products are a poor substitute. I'd do the full deal...troubleshoot with comp. test etc and then tear it down. Head gasket jobs are not hard at all, just messy and time consuming. A good valve job is going to run you $500+ or so with a magnaflux. Don't cut corners with the machine shop either-go to a good one. Do it right, you won't regret it.
Nibor
Aug 21, 2015 09:57 PM
myutesux
Jul 22, 2015 10:01 AM
Viper6913
Apr 25, 2015 11:56 AM
KrautBurner
May 1, 2014 09:42 AM
mcculloughrp
Apr 13, 2008 01:26 AM
