ordered KCM_SD_HPX
Old Oct 7, 2010 | 05:27 PM
ronjon95's Avatar
ronjon95
ordered KCM_SD_HPX
I ordered the high pressure cross over tube I was wondering if there was anything speacial that should be know before the install. It will be next weekend before I will be able to install. Any +'s or -'s of this mod? Any information would be greatfull.
KCM S.S. HPX Line (99-03)
Old Oct 7, 2010 | 05:59 PM
timmyboy76's Avatar
timmyboy76
just installed a RiffRaff HPX, with no issues. Didnt have to remove anything but the 2-bolts, where the line is threaded into. After initial install, fire truck up, and watch for any leaks, maybe rip ur around a few minutes.
Old Oct 7, 2010 | 06:02 PM
jgilrfr's Avatar
jgilrfr
I have one on the way from Riffraff,I have been spraying with PBR to hopefully ease the bolts a little.
Old Oct 7, 2010 | 06:07 PM
timmyboy76's Avatar
timmyboy76
the 2 bolts you'll be removing, where the hpx installs at, are not tight at all, and mine (s.s. tube) snorked in, under the spider/turbo housing, no problem.
03_PSD
26
Jun 19, 2008 08:54 AM
Joe_D
Jun 13, 2008 04:52 PM
TurtleRacing
13
May 11, 2008 02:32 PM
RussB
Apr 1, 2008 02:11 PM
wlihntr
27
May 12, 2005 07:35 AM
