Clutch/ignition Problems??
Old Oct 7, 2010 | 03:07 PM
ajcks1's Avatar
ajcks1
Unhappy Clutch/ignition Problems??
1997 Ranger
This only happens somtimes. I have a manual so to start it you obviously have to press down the clutch. basically what happens is that the starter will do nothing and engine does not turn over or anything. You have to get the clutch in the exact right spot by moving it sligtly up and down to get it to start. When it starts is fires right up. Need Help???
Old Oct 7, 2010 | 03:49 PM
87 XLT's Avatar
87 XLT
The clutch switch connects voltage from the ignition switch to the starter relay. Looks like you need a new clutch switch.
