interchangable head lights???
Old Oct 7, 2010 | 01:44 AM
collinsjon's Avatar
collinsjon
Will 93 and newer head lights fit on a 91 without swapping fenders or hood?
Old Oct 7, 2010 | 07:14 AM
CLR f-150's Avatar
CLR f-150
no im pretty sure they wont, look at your 89 its a big square headlight now look at the 93, it's kindof rounded. Plus the whole nose is different. so yes you would have to change the whole nose to get the 93 style. If your going to do that look at your radiator support to make sure you dont have to change it, my 97 f350 is rotted pretty bad and I should do that sometime here.
Old Oct 8, 2010 | 01:05 AM
collinsjon's Avatar
collinsjon
Thanks. Yeah I just picked up a '91 f350 dually and redoing it. finding accesories for a 91 is alot harder than i thought. I think I will just change the front clip over to a late 90's. seems to be the easiest way to find the good add-ons any way.
Old Oct 8, 2010 | 06:45 AM
CLR f-150's Avatar
CLR f-150
Thumbs up
well good luck with your nose job, I like the mid 90's nose better also.
Old Oct 8, 2010 | 08:31 AM
rla2005's Avatar
rla2005
Good writeup here from another forum: Fullsize Bronco Front End / Clip Swap
Old Oct 9, 2010 | 02:24 AM
collinsjon's Avatar
collinsjon
Thanx for the input guys!
RLA
44
Dec 11, 2011 12:40 AM
PATS2002
Jan 2, 2003 11:40 AM
warmdye
Nov 15, 2002 05:35 PM
beartracks
Apr 9, 2002 08:34 PM
asavage
Aerostar
Feb 28, 2002 05:38 AM
