I think the powerstroke tranny will work. There is something you need to change, but I can't remember what it is. I think David85 knows, and probably others.
the solenoid valves inside the tranny needs to be swapped out then your good to go to use a stroke tranny
hey rupe, that tranny is about 1 1/2 hours north of me. i could maybe pick it up and drop it off in idaho with one of the guys from here, then you can get it from there. i figure if i leave here around 2am id be in idaho by 2pm.
