Problem with Fuel Pump Relay (it dont work)
Old Feb 22, 2003 | 11:57 PM
87ford4x4inline6's Avatar
87ford4x4inline6
Angry Problem with Fuel Pump Relay (it dont work)
I have a 87 f150 4x4x 300, ever since i got this truck the fuel pump relay has given me problems. Have replaced it, cussed it and beat it. I found a short in one of the wires fixed it and still does not work. I have a 87 2 wd that i took the wiring harness off of and it still didnt work. Both harnesses and relay switches work on the 2 wd. I have it bbypassed now, so gas mileage sucks plus it dont ideal when cold.
What am I over looking here?
WHat is causeing this?
The truck runs good. has around 227300.0 miles on it. I swapped the computers from truck to truck. no change on the 4x4. I didnt hook the 4x4's up in the 2 wd tho.
Thanks for reading hopefully someone will have a suggestion to help me.
Old Feb 23, 2003 | 03:12 AM
Miller Tyme's Avatar
Miller Tyme
Can't give you any advice, but my 90 just did the same thing. Replaced the battery, solenoid, starter, had the alternater tested, and gave up. Then tried a test lite on the battery while we pulled wires. Sure enough, the fuel pump relay switch was shorting out the battery after 6-8 hrs. Replaced it, and haven't had any problems...YET.
Old Feb 23, 2003 | 11:02 AM
steve83's Avatar
steve83
If replacing it AND bypassing it didn't solve the problem, then MAYBE the relay ISN'T the problem... How about checking the pump? The fuel lines/filter/pressure regulator/injectors? The tank select switch?
Old Feb 23, 2003 | 06:42 PM
87ford4x4inline6
It works when I bypass it. I have spliced the wires together and it works fine. I would just like to fine out why it wont work the way its suppose to and to get my gas mileage back.
FordAnne
Aug 15, 2023 08:21 AM
Corey Beckwith
1997 - 2003 F150
Apr 29, 2016 07:40 PM
jumbofordman
Feb 2, 2015 05:15 PM
Building_Fords
Nov 14, 2014 07:57 AM
Little old Bronco
Bronco II
26
Dec 1, 2003 07:03 PM
