ANYONE NEED ANYTHING????
Oct 9, 2010 | 03:55 PM
Tecgod13 PM sent. And the seats are sold. I also have a complete early 6.9 engine harness.
Oct 9, 2010 | 04:44 PM
Quote:
Originally Posted by
oreocreaming
I'm takin the psd oit there. The 90 is waiting on gears. I don't thing 12k loaded, 46" tires and 4.10's will work well lol. Hey, I'm goin to PA as well. A buddy has a 7.3l for 800 running well if anyone wants it.
Just the motor or a whole truck?
If it's a truck i want more info...
Oct 9, 2010 | 05:59 PM
7.3l engine only. He's doin a psd swap into it. I'll get info on it and post it here for yall. Oh, if anyone wants a car from the chicago area delivered between there and boston, we can do that too since I'll be empty
Oct 9, 2010 | 06:52 PM
118k 88 brand new g inj. Tuned pump by dps, yeah I've always used fleetguard which has sca's in it already so you don't have to put any in it
that's the info I got from the seller...
Oct 13, 2010 | 10:23 PM
Oct 13, 2010 | 10:38 PM
mechelement
I need a good 6.9L.
I have a 6.9 I pulled out of my truck the engine only had about 120,000 on the motor the IP pump was the only thing wrong with it. and it had a bad rear main gasket but it ran really strong
Oct 13, 2010 | 10:43 PM
What's your location? Why'd you pull the motor?
Oct 13, 2010 | 10:58 PM
mechelement
I live in Caldwell idaho the motor is in Emmett. The only reason I pulled is I bought a 1989 Ford f250 and it had the 7.3 with only 120000 on it.
Oct 13, 2010 | 11:18 PM
Didn't '85 have the block cracking issues at the block heater? You preferred the 7.3 to the 6.9? Is the motor still fully dressed or stripped?
Oct 13, 2010 | 11:24 PM
mechelement
I never had a problem with motor other than IP pump motor runs good just desided to put 7.3 the motor has everything except starter,IP pump AC pump
Oct 14, 2010 | 12:17 AM
How about a york AC compressor bracket that fits in the ford OE location for our trucks???
Oct 14, 2010 | 03:52 AM
serpentine or 9 ve belt compressor brackets. I got both
Oct 14, 2010 | 03:54 AM
the rest of my truck... cheap. taking up to much space. lots of goodies
Oct 14, 2010 | 06:55 AM
mechelement
My understanding is the 85 block is fine, it is the 83-4 blocks that potentially had that issue.
Oct 14, 2010 | 07:07 AM
fellro86
I thought it was addressed after the early '85 and there's a certain range of block numbers to avoid in '85.
