Battery Tray Removal Question
Old Oct 6, 2010 | 06:49 PM
KC63's Avatar
KC63
I thought I might take the battery tray off and clean it up cuz it's kinda rusty.
I started loosening one of the bolts and it seems like there is a nut on the other side (not just a threaded hole)
Do I need to remove the heater to access these nuts?
Old Oct 7, 2010 | 02:52 AM
Wyatt66f100's Avatar
Wyatt66f100
no you wont be able to get to the other side of those nuts if its anything like my 66 (different apron set up) its basically a square nut inside of a cage. if you turn to hard trying to turn through the nut you will spin the nut in the cage and you will never loosen it anymore or tighten it for that matter. the cage on my 66 for the hood springs are impossible to get to. but since it isnt a 66 you could get lucky and find the cage behind the heater box. worth a look i think
Old Oct 8, 2010 | 07:52 PM
Customcab's Avatar
Customcab
63-64 for sure are different then 65-66; the four bolt (9 1/16) I beleive are bolted thru the fire wall and are in a square type nut slevee inside and behind the heater box, these nuts have a tendencie to loose there spot welds; once you remove the heater duct / box area inside the cab you should beable to use a lever like a flat tip screwdriver and wedge the square nut against the side slot while someone else try's to unscrew the bolt.
You can possiblity tach weld the nut back to the fire wall as well.
Hope this helps.
Old Oct 8, 2010 | 09:14 PM
gangstakr's Avatar
gangstakr
You can torch it off, cover the engine bay real good and anything else you don't want hot sparks to hit. Then drill out whats left. weld a stud in it's place. A short carriage bolt should work fine, after all it is not seen because of the battery tray. Make sure you cover the threads before welding.
Wicked Endings
Projects
May 7, 2025 02:21 PM
vntgtrk
49
Mar 16, 2014 05:42 PM
2345.coupe
Projects
34
Dec 25, 2013 05:19 PM
njneer1
Jul 18, 2011 08:53 PM
Wicked Endings
Projects
Jul 30, 2010 11:24 PM
