help
Old Oct 6, 2010 | 06:34 PM
bobby388's Avatar
bobby388
help
i have a 94 f350,abs and brake light comes on and brakes little soft,when i turn truck off and start it again the lights go off,,when i hook up a trailer and have to stop a little hard the rear brakes will lock up,,if you think it is the rabs can i bypass it or will i have to buy a new one(if it is the problem)
Old Oct 6, 2010 | 06:45 PM
Ohio Ford Farm's Avatar
Ohio Ford Farm
check your fluid. Might want to find out why your peddle is soft. That is normally signs of air in the system. Is your peddle low or close to the floor when braking? I would also try changing the sensor in the pumpkin as they good bad often and will cause ABS problems.
Old Oct 6, 2010 | 06:52 PM
bobby388's Avatar
bobby388
i have new master,and also replaced speed sensor on rear end
Old Oct 6, 2010 | 06:53 PM
bobby388's Avatar
bobby388
full of fluid and have also blead system 3 times
Old Oct 6, 2010 | 06:58 PM
bobby388's Avatar
bobby388
new speed sensor blead system 3 times,full of fluid
