Sponsored by: Real Truck
LED tail light wiring help ***UPDATE***
Old Oct 4, 2010 | 09:32 PM
majkthreads's Avatar
majkthreads
I picked up a set of LED tail lights for my 06 F250 CC 6.0 from tunersdepot.com
They are supposed to be plug and play. But when I got them off I cannot for the life of me figure out how they are supposed to plug in. I emailed tunersdepot and I gotta say somebody emailed within 2 hours on a Saturday. But he thought if there was something on the plug from the vehicle that might have to come off in order for them to plug in.
Here's the connector for the new tail lights. Sorry for the bad cell pictures.
Here is the wire coming from the truck that the new light is to plug into: I did take the white piece out and couldn't see how it would plug in.
Here is the websites response from where I bought them.
Usually the point where the taillights connect is the same point where you insert the bulbs into your oem taillights. Does this plug connect to a harness or a plate that then connects to your bulbs? If so, please check if the plate/harness is removable, especially if the plugs on the new LED taillights look like the mail end of your stock light bulbs
Any help would be appreciated. This one has me stumped a little.
Old Oct 4, 2010 | 10:10 PM
djpahan's Avatar
djpahan
That plug looks like the end of 3157 light bulb. Try plug socket into pigtail and replace bulb with this wire that you have in picture.
Old Oct 4, 2010 | 10:30 PM
majkthreads
Thank you djpahan, I never even looked at the bulb when I took it apart. It was getting dark and I didn't want to try and do it in the dark as If I got the one installed I wouldn't stop until the other one was done too.
This is what I felt like when I read your post. Should have slowed down and saw that. Thank you for your help, this place is awesome.
Old Oct 4, 2010 | 11:34 PM
Fordfanatic4life's Avatar
Fordfanatic4life
yea kinda of late but ur new lites plug directly into the plug for your old bulb..
did you buy a "electronic" flasher thou ??? if not your turn signals will flash ultra fast...
ps lets see some pics of your new lites.
Old Oct 5, 2010 | 12:33 AM
majkthreads
No I didn't get a flasher, they said plug n play. I'll have to check it out tomorrow and see what they do. Might have to speak to the guy at the website and see what they have for it.
You guys rock with the help.
Old Oct 5, 2010 | 10:54 PM
majkthreads
Ok update to my LED tail lights. Got them installed in about 5min. flat after looking at the bulb socket.
Here are some pics of the stockers next to the new ones. A little more dramatic when you put them side by side.
Some pics of the day and night look.
Tried a ton of different camera settings to get a good picture of the lights in the dark. They are a whole lot brighter than the stock ones. Even the wife thought they were nice and usually she could care less even if it was on fire.
Old Oct 6, 2010 | 01:24 AM
BCHauler's Avatar
BCHauler
Looks good. I was thinking about the same ones for my truck. I like them because they look a lot like the stock ones.
Old Oct 6, 2010 | 01:43 AM
jackstrr's Avatar
jackstrr
do u BBQ in your truck. looks dangerous. nice looking lights tho
Old Oct 6, 2010 | 02:19 PM
majkthreads
No just had to bring them to church for a bbq.
But it would be nice to have a fold out bbq on it. A new accessory to come up with.
Old Oct 6, 2010 | 02:35 PM
Byram's Avatar
Byram
Buddy of mine has one that fits into the receiver hitch for transport & has 2" sq. tubing that is welded to about an 18" disc (plow) when off the receiver.. Really cool setup - no more lifting in & out of bed... Only problem is cannot open tailgate while in the receiver.. Gotta make sure you put the cooler in first....
Old Oct 6, 2010 | 06:31 PM
BobbyDiesel71's Avatar
BobbyDiesel71
I think those LED are tail lights are RECON
I have them on my truck!
Old Oct 6, 2010 | 08:41 PM
Fordfanatic4life
so did they flash faster ???
Old Oct 6, 2010 | 11:22 PM
majkthreads
No sir, they flashed the same as the stock ones. That was the first thing I looked for when I turned them on.
I got mine from tunersdepot.com They didn't say recon anywhere on the housing so not sure if it's there's.
Old Oct 7, 2010 | 05:49 PM
Fordfanatic4life
hmm thats odd, the LED bulbs normaly require a electronic flasher to stop them from flashing to fast as they dont pull enuf current..
interesting your are working normaly..
Old Oct 7, 2010 | 06:57 PM
WizBangF350's Avatar
WizBangF350
There is likely a resistor in the new light fixtures for each hot wire (bulb filament). With the same resistance as the old light bulbs they will flash the same rate.
they look nice.
