Does anyone know what CXO 10W30 BSP6 oil mean ? Had my first oil change done at the dealer and after reading the invoice they had my engine type wrong (6.8L V10) in stead of 6.7L . Cant call dealer now cause they are closed!!!!!
I don't think you have a problem with the oil only with the guy who wrote the invoice because he is most likely not the one who changed your oil and I would bet he used the right oil
you still need to find out whats in there and untill you do, don't stress your motor.if it's not c-4 rated get it out.
You care to explain to us what "not c-4 rated" oil will do to his motor if he "stresses it"? Long term effects maybe, but short term, it's still a 10w30 oil just lacking the detergent of diesel oil and likely having a lower TBN.
Maybe the sky is falling and I'm the only chicken that doesn't see it!
almost any oil will lubricate a motor that is just running at low load and low rpm. when it is being stressed ,it needs special build quality to perfarm. seein that we don't know what oil he has ,let's change it just to be sure, a new motor is a lot more than 14 qts of oil.
FIRES OUT !!!! What happened is that cumputer error on the "Know your vehicle program" caused it to write the wrong engine type on the report. The service adviser says the it has a problem with the new vin numbers. Thanks for the support!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!
