The OOOHFISHALLY sanctioned NS B/S Chat thread!
Received 4,195 Likes
on
on
As long as they don't drag too tight on the threshold they last a good while. I use these doors a lot running back and forth to the shop and since 87 when I built this place have only changed them out a couple times. The door going into my shop which I built in 2005 still has the original on it, I should probably check it to see if it needs changing..
on
We put a new front door in when we changed all the windows and I'm not too happy with them. I had triple pane glass before but was talked out of it saying I was wasting my money because double panes were good enough for this area. I should have trusted my own instincts but can't afford to change them out again now and the front door weather stripping is crap because it frosts up around the door. We complained to manufacturer and they told us our problem was too much humidity in the house and that is BS because it's at 35% and you can't touch a thing without getting a shock from the static electricity...
on
on
on
on
