Sponsored by: Real Truck
5.4 SD roaring under load
Old Oct 3, 2010 | 07:55 PM
flying low's Avatar
flying low
My 01 5.4 SD sometimes "roars", makes a loud noise, when towing a heavy trailer or with a heavy load in the bed when accelerating. It can usually be stopped by backing off on the accelerator momentarily. Any ideas?
Old Oct 3, 2010 | 08:46 PM
jndinmo's Avatar
jndinmo
Probably the fan?
Old Oct 3, 2010 | 09:40 PM
jc8825's Avatar
jc8825
Yeah, the fan.
Old Oct 3, 2010 | 11:35 PM
Monsta's Avatar
Monsta
Sit. Stay.
Your truck's engine is equipped with a fan clutch.
This "clutch" works so that when the fan is not needed to cool the engine it will have the fan run at less than 1 to 1 with the engine. Meaning: it turns slower than the engine. This is done for fuel economy and performance reasons.
The clutch is controlled by heat that comes from the radiator. If the heat from the radiator is is beyond a certain threshold, the fluid inside the clutch will thicken and make the fan spin 1:1 with the engine. This is the roar that you hear.
