Batteries-how strong?
Old Oct 3, 2010 | 04:49 PM
barca_texas's Avatar
barca_texas
I think I am getting air in my fuel. (i've got a return line kit to put on)
Checked all my glow plugs- they measure ok- glow plug controller stays on for 6 secs, 83 degrees in Tx.
I have only been getting it to start by pressing and holding the pedal all the way down and cranking for 10secs.
This symptom has been getting worse (I am putting the return kit on NOW)
But today it would not fire at all...
Notice that cranking is a bit slower. But it fired with an ether shot.
Batteries measure 12.71 and 12.73 volts...
I dont know the age of the batteries, one is for sure fairly new (looking).
I searched the forum before writing...
How fast does the motor have to spin/how strong do the batteries have to be?
I know this is a subjective question, but.... thanks to dave and festus for the help. Jery
Learning Diesel is Like Learning a new language! boy am I slo
Old Oct 3, 2010 | 05:00 PM
85grey's Avatar
85grey
I thought my batteries were ok because I was testing them when they were hooked up. Then using a load tester, not a multimeter I tried with them unconnected and found one was a dead short
Old Oct 3, 2010 | 07:52 PM
farmert's Avatar
farmert
If you can count the revs when the engine is cranking it is to slow. Check all battery cable connections both pos. and neg. they need to be clean and tight on both ends of the battery cables.Extended cranking can burn the starter up, 20 seconds max cranking with 2 minutes cool down before cranking again.
Old Oct 4, 2010 | 10:04 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Generally Diesels take between 100 and 200 RPM to start reliably, faster the better. (to a point)
As already stated, using a volt meter to test battery voltage is very misleading, they can have full voltage yet be junk!
They MUST be tested under load to determine the condition ...
A DIY method that give a better clue, is to test the voltage with everything drawing power ... Lights, Blowers, Starter ... More items on the better.
-Enjoy
fh : )_~
Metz12345
Jan 19, 2015 06:48 AM
brokeasajoke
Dec 6, 2013 09:27 PM
Pele
25
Apr 16, 2013 11:19 PM
Dan Taylor
Jan 17, 2013 06:54 PM
DeWaltManZ
Feb 28, 2011 09:01 AM
