rear differential code info
Old Oct 3, 2010 | 03:59 PM
medicdave's Avatar
medicdave
I have a 2000 Excursion with the 6.8l V-10. The following information is from the rear differential tag. Could someone please tell me what this all means. I am trying to determine my gear ratio. There is some rust so some of the numbers are hard to read.
PM 421 D
30 10 5 9 H23
Old Oct 3, 2010 | 04:16 PM
spinella's Avatar
spinella
do you still have the sticker on the inside of the drivers door? here are some codes from the superduty section. https://www.ford-trucks.com/forums/4...lder_____.html
Old Oct 3, 2010 | 04:20 PM
spinella's Avatar
spinella
here you go. check that sticker...
Axle Type
31 — 3.73 non-limited slip, F-250/Excursion
C1 — 3.73 limited slip, F-250/Excursion
32 — 4.10 non-limited slip, F-250
C2 — 4.10 limited slip, F-250/Excursion
33 — 4.30 non-limited slip, F-250
C3 — 4.30 limited slip, F-250/Excursion
dieselsubmariner
Apr 27, 2014 10:08 PM
V10Block
Modular V10 (6.8l)
Jul 18, 2012 08:56 PM
kevin.ford-trucks
May 17, 2008 06:34 PM
Budkole
Aug 24, 2005 12:13 PM
BlueKnight
Mar 7, 2005 03:20 PM
