Engine Id and starter problems
The starter keeps working itself out of alignment. when it starts to grind I have to climb under the truck and remove it, Then pry the spacer straight (between the bell housing and block) and then reinstal it. This only lasts 3 or 4 days and it starts grinding again, and I have to do it all over again. Meanwhile I'm chewing the hell out of my starter gears and fexplate.
Here are the numbers that I have
EOAF D3C and a sidways 20
the way its writen is starange to me as well and I have a picture but I cant figure out how to post it so it is on my facebook located here
Login | Facebook
if you know how to post photos please add it to your responce, or tell me how.
UPDATE, I read the sidways number wrong and fixed it up there
Also when I remove the starter to fix the problem again, the bolts are still tight
