Sponsored by: Auxito
88 octane
Old Feb 22, 2003 | 02:27 PM
mountainman's Avatar
mountainman
88 octane
i found this gas station by my house that sells gas consistently 5 to 10 cents cheaper. it doesnt sell 87 octane, just 88. does that matter in terms of firing, performance? i cant tell any difference.
Old Feb 22, 2003 | 03:08 PM
kspilkinton's Avatar
kspilkinton
88 octane
You shouldn't see any performance difference on a positive 1 octane point. It helps with compression/temp preignition, so the higher compression ratio (or higher the engine temp, or longer the stroke) the engine is, the higher the recommended octane.
The reason some places sell differently rated gas is because of altitude. In older pre-computer engines or those that aren't calibrated to higher altitudes 85, 88, and 91 are ok. These ratings are common in high altitude locations for smog reasons and the air is thin. Calibrated/ computer controlled engines are designed to run the manufacturers recommended octane rating, so 88 is ok in an 87 rated engine if calibrated, but 85 lacks the same qualities and provides for bad mileage (and puts out more pollution per gallon) in those situations.
-Kerry
Old Feb 22, 2003 | 03:43 PM
FTE Ken's Avatar
FTE Ken
88 octane
85 will work fine in higher elevations for 87 octane engines. The higher the elevation, the lower the octane required. Many Fords don't benefit from higher octane because the knock sensor isn't always activated.
89f350xlt
Nov 7, 2015 06:43 PM
Binkowski
49
Dec 2, 2014 07:06 PM
lawnspecialties
6.2L V8
May 23, 2014 12:09 PM
projectdagger
Mar 3, 2007 02:45 PM
Phinxter
General Automotive Discussion
19
Mar 16, 2006 06:07 PM
