75 F-250 ignition trouble
While I had the distributor out some kind of plastic spacer came out of the distributor from under the main plate. (Link to the picture)
Fell out of | Flickr - Photo Sharing! Didn't think much of it until I got every thing back together and had no spark. I ran the gambit checking things. From the ignition to coil 12.44 volts. from coil out 12.44 volts Checked resistance to coil about 0.4 but thats when it took me for a spin I found my distributor is grounded and I'm pulling a ground from the coil wire to the distributor whether the points are opened or not. So my though is this plastic pin / spacer some sort of insulator that fell out? If you can help I sure would appreciate it. If you want to view the other photo's from this adventure in shade tree mechanics... Flickr: SethAPrather's Photostream
Take your wires loose off the points, and see if the wires are still grounded. If they are, you must have a short to ground to one of the wires, or the condensor is shorted if that wire is still grounded.
If the ground went away, make sure the points are open, or stick a piece of cardboard inbetween the points, and check for a ground at the points terminal. If they are still grounded, check that the insulating block where the terminal is located is ok.
That how the points work. They ground, and then unground the negative of the coil. The + of the coil is there all the time the key is in run. The grounding and ungrounding of the negative terminal of the coil is what makes the spark.
"If the ground went away, make sure the points are open, or stick a piece of cardboard inbetween the points, and check for a ground at the points terminal. "If they are still grounded, check that the insulating block where the terminal is located is ok."
Regards,
Seth
You can see in the above picture the terminal and the arm are mounted in plastic. The mounting holes are bolted to the dist, which should have a ground wire hooked to the plate the points mount to. So when the points come together, they are connecting the wires on the terminal to ground.
I figured it out last week and should have responded. It was the condenser grounding out againt the bottom plate of the distributor. It has a U-type connector that I had placed on the insulator block with the legs of the U pointing up. the top of that connector is unusually tall and it was hitting the bottom plate. I spun it around and presto change-o I was no longer grounding out. Thanks for all of your help.
