Torque Spec?
Old Oct 2, 2010 | 07:01 PM
HD Rider's Avatar
HD Rider
Torque Spec?
Does anyone know the torque Spec for the bearing caps in the front axle. It's a Dana 50 front end. I am doing inner axle seals and putting the diff back in now.
Old Oct 2, 2010 | 07:36 PM
Stewart_H's Avatar
Stewart_H
Are you talking about the axle nut that holds the bearings?
If yes, it's 18ft lbs.
I always do it by feel. Tighten it up well past 18 to seat the bearing, then back off and tighten down to 18ft lbs. in one motion.
Stewart
Old Oct 2, 2010 | 08:08 PM
rbaker6336's Avatar
rbaker6336
The Dana manual says 80 to 90 Ft lbs for bearing caps
http://www2.dana.com/pdf/5326.pdf
Old Oct 2, 2010 | 09:01 PM
HD Rider's Avatar
HD Rider
Mine is not an independent but Ray got it. Thanks!
Old Oct 2, 2010 | 09:07 PM
rbaker6336's Avatar
rbaker6336
For some reason the only D50 Dana has on their site is the IFS,but the important stuff should be the same
Old Oct 2, 2010 | 10:41 PM
Stewart_H's Avatar
Stewart_H
Ok, obviously I was thinking about the wrong part!
Stewart
Old Oct 6, 2010 | 08:39 PM
HD Rider's Avatar
HD Rider
Looks like you were thinking I had a 2 wheel drive.
